Ho provato a installare lizmap su un VPS con ubuntu 16.04 X64 e sembra sia
andata a buon fine, visualizzo il pannello admin etc.. ma non riesco a
visualizzare le mappe in quanto i servizi WMS e WFS di qgis server non
sembrano funzionare.
http://89.47.161.54/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
ricevo un Internal Server Error!
con *find / -name 'qgis_mapserv.fcgi' *
ricevo /usr/lib/cgi-bin/qgis_mapserv.fcgi
"lanciando"
/usr/lib/cgi-bin/qgis_mapserv.fcgi Warning 1: Unable to find driver ECW
to unload from GDAL_SKIP environment variable.
Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment
variable.
Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP environment
variable.
variable.
variable.
Content-Type: text/xml; charset=utf-8
Content-Length: 206
<ServiceExceptionReport version="1.3.0" xmlns="http://www.opengis.net/ogc">
<ServiceException code="Service configuration error">Service unknown or
unsupported</ServiceException>
</ServiceExceptionReport>
fin qui sembra tutto regolare!
ho creato il mio /etc/apache2/sites-available/qgis.nico.conf
cosi:
https://pastebin.com/uNvGhpRe
e lanciato
a2enmod fcgid
a2ensite qgis.nico
service apache2 restart
il log error:
https://pastebin.com/8QnNfnp0
e qgis.nico.error log
https://pastebin.com/D2K1eiMN
Hai abilitato cgi?
[http://89.47.161.54/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities](http://89.47.161.54/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities)
"lanciando"
variable.
variable.
variable.
variable.
Content-Length: 206
cosi:
[https://pastebin.com/uNvGhpRe](https://pastebin.com/uNvGhpRe)
e lanciato
a2enmod fcgid
a2ensite qgis.nico
il log error:
[https://pastebin.com/8QnNfnp0](https://pastebin.com/8QnNfnp0)
[https://pastebin.com/D2K1eiMN](https://pastebin.com/D2K1eiMN)
Sent from: [http://osgeo-org.1560.x6.nabble.com/QGIS-Italian-User-f5250612.html](http://osgeo-org.1560.x6.nabble.com/QGIS-Italian-User-f5250612.html)
QGIS-it-user mailing list
QGIS-it-user@lists.osgeo.org
[https://lists.osgeo.org/mailman/listinfo/qgis-it-user](https://lists.osgeo.org/mailman/listinfo/qgis-it-user)
Sorry for being short
questo è il mio
/etc/apache2/conf-available/php.conf
https://pastebin.com/H6Uvsvr2
e questo
/etc/apache2/conf-available/serve-cgi-bin.conf
https://pastebin.com/jN5fQAiz
php7.0-cgi-bin
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
Action application/x-httpd-php /cgi-bin/php7.0
non so se manca altro
Non so per quale motivo lanciavo sudo a2ensite 001-qgis e non quello che
avevo editato: 000-default
qualche passo avanti lo ho fatto..
ora funziona
quindi credo che il problema con qgis server sia risolto...
per quanto riguarda lizmap invece ci devo ancora "lavorare"
vedo la mappa.. purtroppo senza i punti..
http://89.47.161.54/lm/index.php/view/map/?repository=nicoali&project=alberi
I dati sono raggiungibili sul server, con lo stesso path?
ora funziona
[http://89.47.161.54/lm/index.php/view/map/?repository=nicoali&project=alberi](http://89.47.161.54/lm/index.php/view/map/?repository=nicoali&project=alberi)
Ciao,
ho provato il tuo link e mi sembra che funziona, Vedo la mappa di base e
anche gli "censimento alber", basta abilitare la casella del layer....
Fabio
