Buongiorno a tutti,
dopo un mega aggiornamento del sistema operativo di questo finesettimana, Qgis stamane ha ben pensato di non avviarsi e di non voler avviarsi causa l’errore 0xc000007b…come possiamo risolverlo?
Devo reinstallare Qgis?
Devo formattare e reinstallare Windows 10?
Attendo news grazie mille
Alessandro
AV1
May 2, 2016, 8:03am
2
1] premi WIN-R
2] digita CMD e dai ok
3] digita SET e dai ok
copia ed incolla qui il risultato del suddetto comando SET, grazie.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Qgis-su-Windows-10-errore-0xc000007b-tp5263830p5263843.html
Sent from the QGIS Italian User mailing list archive at Nabble.com.
ALLUSERSPROFILE=C:\ProgramData
APPDATA=C:\Users\Ragnar\AppData\Roaming
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=RAGNARNOTEBOOK
ComSpec=C:\Windows\system32\cmd.exe
C_EM64T_REDIST11=C:\Program Files (x86)\Common Files\Intel\Shared Files\cpp
FPS_BROWSER_APP_PROFILE_STRING=Internet Explorer
FPS_BROWSER_USER_PROFILE_STRING=Default
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Users\Ragnar
LOCALAPPDATA=C:\Users\Ragnar\AppData\Local
LOGONSERVER=\RAGNARNOTEBOOK
NUMBER_OF_PROCESSORS=8
OS=Windows_NT
Path=C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Files\cpp\bin\Intel64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Program Files\Calibre2;C:\Program Files (x86)\Skype\Phone;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Files\cpp\bin\Intel64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\Program Files\Calibre2;C:\Program Files (x86)\Skype\Phone;C:\Program Files (x86)\Graphviz2.30\bin
PATHEXT=.COM ;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 58 Stepping 9, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=3a09
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules
PUBLIC=C:\Users\Public
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\Windows
TEMP=C:\Users\Ragnar\AppData\Local\Temp
TMP=C:\Users\Ragnar\AppData\Local\Temp
USERDOMAIN=RagnarNotebook
USERDOMAIN_ROAMINGPROFILE=RagnarNotebook
USERNAME=Ragnar
USERPROFILE=C:\Users\Ragnar
windir=C:\Windows
2016-05-02 10:03 GMT+02:00 AV <antoniovinci@wp.pl >:
1] premi WIN-R
Sent from the QGIS Italian User mailing list archive at Nabble.com .
QGIS-it-user mailing list
QGIS-it-user@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-it-user
AV1
May 2, 2016, 8:32am
4
Quante partizioni ha il tuo disco fisso, oltre a C..?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Qgis-su-Windows-10-errore-0xc000007b-tp5263830p5263850.html
C dove c’è il sistema operativo ed E dove tengo solo i documenti
2016-05-02 10:32 GMT+02:00 AV <antoniovinci@wp.pl >:
Quante partizioni ha il tuo disco fisso, oltre a C…?
AV1
May 2, 2016, 9:19am
6
Potrebbe essere un problema di diritti in scrittura.
Provare non costa niente, allora:
1] crea un direttorio TEMPO nella radice di E
2] apri la suddetta finestra Dos, e dai i comandi:
SET TMP=E:\TEMPO
SET TEMP=E:\TEMPO
3] riavvia il pc
4] come nel post precedente, dai il solo comando SET, accertandoti che le
variabili TMP e TEMP siano effettivamente impostate su E:\TEMPO
5] ora lancia Qgis: che succede?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Qgis-su-Windows-10-errore-0xc000007b-tp5263830p5263863.html
Purtroppo lo stesso errore
SET TMP=E:\TEMPO
SET TEMP=E:\TEMPO
3] riavvia il pc
AV1
May 3, 2016, 4:58am
8
Spiacente, su un pc al lavoro avevo risolto cosi’, ma evidentemente non e’ una formula universale…
Senti, e che accade se provi a lanciare Qgis senza plugin?
Praticamente devi editare l’icona di lancio, aggiungendogli in coda la stringa --noplugins, tipo:
“C:\Program Files\QGIS Essen\bin\nircmd.exe” exec hide C:\PROGRA~1\QGISES~1\bin\qgis.bat --noplugins
View this message in context: Re: Qgis su Windows 10 - errore 0xc000007b
RISOLTO!!!
Ho risolto reinstallando i pacchetti dll probabilmente corrotti dall’aggiornamento…adesso sembra funzionare tutto, non lo diciamo troppo forte però!
Il giorno 3 maggio 2016 06:58, AV <antoniovinci@wp.pl > ha scritto:
Spiacente, su un pc al lavoro avevo risolto cosi’, ma evidentemente non e’ una formula universale… Senti, e che accade se provi a lanciare Qgis senza plugin? Praticamente devi editare l’icona di lancio, aggiungendogli in coda la stringa --noplugins, tipo: “C:\Program Files\QGIS Essen\bin\nircmd.exe” exec hide C:\PROGRA~1\QGISES~1\bin\qgis.bat --noplugins
