Tankyou Andrea,
now i tried ti install also a stadalone version but dont work again.
Il 29/06/2022 13:36, Andrea Giudiceandrea via Qgis-user ha scritto:
*Leonardo Donnini*ldonnini at bonibit.com <mailto:qgis-user%40lists.osgeo.org?Subject=Re%3A%20[Qgis-user]%20Udate%20QGIS%203.26.0&In-Reply-To=<540a559d-4f12-0f0f-8d76-ccc8fb60df74%40bonibit.com>>
/Wed Jun 29 04:15:41 PDT 2022/
update to 3.26.0 failed :
VCRUNTIME140_1.dll not found
Hi Leonardo,
what do you mean exactly with "update to 3.26.0"?
Are you updating a previous QGIS installation using the OSGeo4W Network Installer *
R: YES*
or are you installing QGIS using the OSGeo4W Standalone Installer?
What QGIS version are you trying to update to QGIS 3.26.0?
*R: QGIS 3.24.2*
Is your Operative System a 64 bit one?
*YES*
Best regards.
Qgis-user mailing list
Qgis-user@lists.osgeo.org
List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Leonardo Donnini ldonnini at bonibit.com
Hi Leonardo,
I’ve never seen such issue and it seems to me it was never previously reported in https://github.com/qgis/QGIS/issues nor in https://trac.osgeo.org/osgeo4w/.
This issue is specific to the OSGeo4W installation, so it would be very useful if you could create a new detailed ticket in https://trac.osgeo.org/osgeo4w/.
The VCRUNTIME140_1.dll is part of the Microsoft Visual C++ Redistributable Package and usually it is installed by the OSGeo4W installer if missing (the “msvcrt2019” package).
As a workaround I think you can try to manually install the Microsoft Visual C++ Redistributable Package (Visual Studio 2015, 2017, 2019 e 2022) from https://support.microsoft.com/help/2977003/the-latest-supported-visual-c-downloads (I think both x86 and x64 are needed).
Best regards.
Hi Andrea,
after manually installed the Microsoft Visual C++ Redistributable Package (Visual Studio 2015, 2017, 2019 e 2022) the error message loading QGIS was changed in :
Could not load qgis_App.dll
Windows error: runtime di inizializzazione della libreria di collegamento dinamico (DLL) non riuscita.
Chek C:\OSGeo4W\bin\qgis-bin.env for correct enviroment path
are there others suggestion ?
Thanks
Leonardo
Hi Leonardo,
Best regards.
Hi Leonardo,
have you updated all the installed OSGeo4W packages to the latest versions using the OSGeo4W Setup?
Some issues that could lead to the “Could not load qgis_App.dll” error in particular systems have been recently fixed in the latest version of some packages.
Otherwise, in this cases checking what’s wrong with the DLLs is needed as described in https://trac.osgeo.org/osgeo4w/ticket/748#comment:5 and https://github.com/qgis/QGIS/issues/26891#issuecomment-495889169
Best regards.
Il 04/07/2022 09:31, Leonardo Donnini ha scritto:
Hi Andrea,
