Boa tarde,
Gostaria de colocar 1 questão. A tentar executar a ferramenta “grass” pelo QGIS (versão + recente com instalação via OSGeo4W, numa máquina windows 10, 64 bits.
Creio que o que aborta o processo será a impossibilidade de utilizar a livraria GDAL, mas não percebo como solucionar:
2021-07-20T14:05:39 INFO GRASS GIS 7 execution console output
Starting GRASS GIS…
WARNING: Concurrent mapset locking is not supported on Windows
Cleaning up temporary files…
Executing …
C:\OSGeo4W\bin>chcp 1252 1>NUL
C:\OSGeo4W\bin>g.proj -c wkt=“C:/Users/Particular/AppData/Local/Temp/processing_MbcDzX/cdd299bd36d6449fb1270f6e559b3652/crs.prj”
Default region was updated to the new projection, but if you have multiple mapsets g.region -d should be run in each to update the region from the default
Projection information updated
C:\OSGeo4W\bin>r.external input=“G:\FICHEIROS_DADOS\CONSULTORIA\CM_XXX\GIS\MDT\MDT_140401v2.tif” band=1 output=“rast_60f6ca2232fda2” --overwrite -o
Over-riding projection check
Reading band 1 of 1…
ERROR: Unable to load GDAL library
C:\OSGeo4W\bin>g.region n=-39620.35982039999 s=-55560.3505752 e=-30548.607124000002 w=-43733.4816028 res=4.999952399999999
C:\OSGeo4W\bin>r.fill.dir input=rast_60f6ca2232fda2 format=“grass” output=output89153a1a560e43489194c61612739fcd direction=direction89153a1a560e43489194c61612739fcd areas=areas89153a1a560e43489194c61612739fcd --overwrite
C:\OSGeo4W\bin>g.region raster=output89153a1a560e43489194c61612739fcd
ERROR: Raster map not found
C:\OSGeo4W\bin>r.out.gdal -t -m input=“output89153a1a560e43489194c61612739fcd” output=“C:\Users\Particular\AppData\Local\Temp\processing_MbcDzX\a76ab4e5d68b45f1b6c2739e58437da5\output.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
ERROR: Raster map or group not found
C:\OSGeo4W\bin>g.region raster=direction89153a1a560e43489194c61612739fcd
C:\OSGeo4W\bin>r.out.gdal -t -m input=“direction89153a1a560e43489194c61612739fcd” output=“C:\Users\Particular\AppData\Local\Temp\processing_MbcDzX\fde16642fbfe463c9cc71ea2c0f08ee3\direction.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
C:\OSGeo4W\bin>g.region raster=areas89153a1a560e43489194c61612739fcd
C:\OSGeo4W\bin>r.out.gdal -t -m input=“areas89153a1a560e43489194c61612739fcd” output=“C:\Users\Particular\AppData\Local\Temp\processing_MbcDzX\cf65f88ad3124782932644f6fb6dd822\areas.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
C:\OSGeo4W\bin>exit
Execution of finished.
Press any key to continue . . .
Ajuda, será bem vinda
Obrigado
Cumprimentos,
Valter Albino - Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
talvez seja este:
https://github.com/qgis/QGIS/issues/44155
Cumprimentos
-- G --
On Tue, Jul 20, 2021 at 2:13 PM Valter Albino <valteralbino@gmail.com> wrote:
Boa tarde,
Gostaria de colocar 1 questão. A tentar executar a ferramenta "grass" pelo QGIS (versão + recente com instalação via OSGeo4W, numa máquina windows 10, 64 bits.
Starting GRASS GIS...
Cleaning up temporary files...
Executing ...
C:\OSGeo4W\bin>g.proj -c wkt="C:/Users/Particular/AppData/Local/Temp/processing_MbcDzX/cdd299bd36d6449fb1270f6e559b3652/crs.prj"
Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default
C:\OSGeo4W\bin>r.external input="G:\FICHEIROS_DADOS\CONSULTORIA\CM_XXX\GIS\MDT\MDT_140401v2.tif" band=1 output="rast_60f6ca2232fda2" --overwrite -o
Reading band 1 of 1...
C:\OSGeo4W\bin>r.fill.dir input=rast_60f6ca2232fda2 format="grass" output=output89153a1a560e43489194c61612739fcd direction=direction89153a1a560e43489194c61612739fcd areas=areas89153a1a560e43489194c61612739fcd --overwrite
C:\OSGeo4W\bin>r.out.gdal -t -m input="output89153a1a560e43489194c61612739fcd" output="C:\Users\Particular\AppData\Local\Temp\processing_MbcDzX\a76ab4e5d68b45f1b6c2739e58437da5\output.tif" format="GTiff" createopt="TFW=YES,COMPRESS=LZW" --overwrite
C:\OSGeo4W\bin>r.out.gdal -t -m input="direction89153a1a560e43489194c61612739fcd" output="C:\Users\Particular\AppData\Local\Temp\processing_MbcDzX\fde16642fbfe463c9cc71ea2c0f08ee3\direction.tif" format="GTiff" createopt="TFW=YES,COMPRESS=LZW" --overwrite
C:\OSGeo4W\bin>r.out.gdal -t -m input="areas89153a1a560e43489194c61612739fcd" output="C:\Users\Particular\AppData\Local\Temp\processing_MbcDzX\cf65f88ad3124782932644f6fb6dd822\areas.tif" format="GTiff" createopt="TFW=YES,COMPRESS=LZW" --overwrite
C:\OSGeo4W\bin>exit
Obrigado
Cumprimentos,
QGIS-pt mailing list
QGIS-pt@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/qgis-pt
É possível
A mesma versão 3.20.0 no portátil “laptop” executa sem problemas …
QGIS version
3.20.0-Odense
QGIS code revision
decaadbb31
Qt version
5.15.2
Python version
3.9.5
GDAL/OGR version
3.3.0
PROJ version
8.0.1
EPSG Registry database version
v10.018 (2021-04-02)
GEOS version
3.9.1-CAPI-1.14.2
SQLite version
3.35.2
PDAL version
2.3.0
PostgreSQL client version
13.0
SpatiaLite version
5.0.1
QWT version
6.1.3
QScintilla2 version
2.11.5
OS version
Windows 10 Version 1909
Giovanni Manghi <giovanni.manghi@gmail.com> escreveu no dia terça, 20/07/2021 à(s) 14:44:
Obrigado
Cumprimentos,
