[QGIS-pt] slope lenght
boa tarde!
alguem me sabe responder se a ferramenta o SAGA no QGIS slope lenght é equivalente ao folw accumulation no arcgis.
obrigado
Olá,
2014-04-30 15:54 GMT+01:00 david pulquerio <pulquerio2003@yahoo.com>:
boa tarde!
acho que sim, infelizmente a documentação de SAGA as vezes não ajuda
(estou a dar uma vista de olhos no manual oficial e na "biblia" de
Victor Olaya).
Entretanto acho que ficas bem servido com r.watershed
DESCRIPTION
r.watershed generates a set of maps indicating: 1) flow accumulation,
drainage direction, the location of streams and watershed basins, and
2) the LS and S factors of the Revised Universal Soil Loss Equation
(RUSLE).
Flags:
-f
Enable MFD flow (default is SFD (D8))
SFD: single flow direction, MFD: multiple flow direction
-4
Allow only horizontal and vertical flow of water
-m
Enable disk swap memory option: Operation is slow
Only needed if memory requirements exceed available RAM; see manual on
how to calculate memory requirements
-a
Use positive flow accumulation even for likely underestimates
See manual for a detailed description of flow accumulation output
--overwrite
--verbose
Verbose module output
--quiet
Quiet module output
Parameters:
elevation=name
Input map: elevation on which entire analysis is based
depression=name
Input map: locations of real depressions
flow=name
Input map: amount of overland flow per cell
disturbed.land=string
Input map or value: percent of disturbed land, for USLE
blocking=name
Name of input raster map blocking overland surface flow
Input map: terrain blocking overland surface flow, for USLE
accumulation=name
Name for output accumulation raster map
Output map: number of cells that drain through each cell
drainage=name
Output map: drainage direction
basin=name
Output map: basins raster map
stream=name
Output map: stream segments
half.basin=name
Output map: half basins raster map
visual=name
Output map: useful for visual display of results
length.slope=name
Name for output slope length raster map
Output map: slope length and steepness (LS) factor for USLE
slope.steepness=name
Name for output slope steepness raster map
Output map: Slope steepness (S) factor for USLE
threshold=integer
Input value: minimum size of exterior watershed basin
max.slope.length=float
Input value: maximum length of surface flow, for USLE
convergence=integer
Convergence factor for MFD (1-10)
1 = most diverging flow, 10 = most converging flow. Recommended: 5
Default: 5
memory=integer
Maximum memory to be used with -m flag (in MB)
Default: 300
Giovanni Manghi
Faunalia.pt
Sistemas de Informação Geográfica Open Source
Portugal
Web: http://www.faunalia.pt
Email & Jabber: giovanni.manghi@faunalia.pt
PGP Key available
Tel. + 351 96 7058216
Olá Giovanni,
2014-04-30 18:03 GMT+01:00 Giovanni Manghi <giovanni.manghi@faunalia.pt>:
Olá,
boa tarde!
(estou a dar uma vista de olhos no manual oficial e na “biblia” de
Victor Olaya).
Eu penso que não. Para esse efeito as ferramentas a usar são as “Catchment Area (…)”. Se bem me lembro, são ferramentas BASTANTE mais potentes que o flow accumulation do ArcGIS.
Creio que a slope lenght devolve a “hipotenusa” do plano inclinado (declive) - http://www.proprofs.com/flashcards/upload/a5617929.png Mas não tenho certeza absoluta e neste momento não consigo confirmar.
DESCRIPTION
(RUSLE).
Sim, r.watershed foi a ferramenta que já usei várias vezes para esse efeito.
Abraço,
Pedro
Obrigado pela ajuda!
Eu entretanto fui diretamente ao grass e calculei o flowaccumulation através do r.terraflow.
vou agora se seguir o vosso conselho e utilizar o r.watershed e comparar resultados.
muito obrigado
D.P
On Wednesday, April 30, 2014 7:45 PM, Pedro Venâncio pedrongvenancio@gmail.com wrote:
Olá Giovanni,
Olá,
boa tarde!
Victor Olaya).
DESCRIPTION
(RUSLE).
Abraço,
Pedro
QGIS-pt mailing list
QGIS-pt@lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/qgis-pt
Boa tarde David,
Podes também testar com a ferramenta Catchment area (parallel) do SAGA. Já testei, funciona e é ainda mais flexível.
Abraço,
Pedro
No dia 2 de Maio de 2014 às 11:10, david pulquerio <pulquerio2003@yahoo.com> escreveu:
muito obrigado
D.P
On Wednesday, April 30, 2014 7:45 PM, Pedro Venâncio <pedrongvenancio@gmail.com> wrote:
Olá Giovanni,
Olá,
boa tarde!
Victor Olaya).
DESCRIPTION
(RUSLE).
Abraço,
Pedro
