QGIS-server + Qtiler
Hi everyone,
I wanted to share a tool that might be very useful if you are working with QGIS Server or publishing maps to the web.
If you need to improve performance by creating WMTS or XYZ caches from your QGIS projects, check out Qtiler. It is an Open Source tool designed to generate static tiles directly from your .qgs/.qgz projects or from your WMS created with your QGIS-server.
Why use it?
  • Boost Performance: It significantly speeds up map rendering compared to dynamic WMS.
  • Native Rendering: Since it relies on QGIS libraries, your complex styles and labeling look exactly as they do on desktop.
  • Easy to use: No programming is needed—just download, install, and run.
Read more and download here: https://github.com/MundoGIS/Qtiler
It is completely free and Open Source. I would love to hear your feedback or if you encounter any issues!
Best regards,
Abel MundoGIS
