QGIS Tips
:brain: General Usage Tips
  • Use the Locator Bar (Ctrl+K) to quickly access layers, tools, and settings.
  • Customize your UI via Settings > Interface Customization to streamline your workspace.
  • Enable Auto-Save Projects under Settings > Options > General to prevent data loss.
:toolbox: Processing Toolbox Shortcuts
Task Tool Shortcut
Clip vector layer Clip Search: “clip”
Buffer geometries Buffer Search: “buffer”
Merge rasters Merge Search: “merge raster”
Reproject layer Reproject layer Search: “reproject”
:test_tube: Expression Cheat Sheet
Function Purpose Example
area($geometry) Calculate area Polygon area
length($geometry) Line length Road segments
crsfromstring(‘EPSG:4326’) Set CRS Useful in models
reverse(‘Jinka’) Reverse string Returns “akniJ”
repeat(‘Hazard’, 3) Repeat string Returns “HazardHazardHazard”
:card_index_dividers: Layer & Data Tips
  • Use Layer Groups to organize complex projects.
  • Apply WMS-T time dimension to group nodes for temporal mapping.
  • Use Select by Expression for advanced filtering (e.g., risk_level = ‘high’ AND region = ‘South’).
:books: Learning Resources
  • QGIS Training Manual: Step-by-step modules from basic mapping to spatial databases.
  • QGIS 3.44 Changelog: Full list of new features and enhancements.
