Qtiler, the new WMS, WFS, WMTS tool for QGIS
Hi everyone! :waving_hand:
For the GIS Administrators and System Architects here: If your organization relies on QGIS and you need a way to publish maps that is both secure and extremely fast, I’d like to introduce you to Qtiler.
:hammer_and_wrench: What is Qtiler? It is an Open Source Node.js application that leverages QGIS Desktop native libraries to serve data. It turns your .qgs/.qgz projects into standard OGC services without the overhead of Java-based middleware.
:office_building: Why is this beneficial for your Organization?
  1. :high_voltage: Speed & Scalability: Built on Node.js, it handles concurrent requests efficiently. Pre-rendered WMTS/XYZ tiles load instantly, removing load from your database.
  2. :locked: Security: By serving pre-rendered tiles or controlled WFS, you reduce direct exposure to your backend databases. It sits perfectly behind IIS/Nginx reverse proxies.
  3. :artist_palette: Data Integrity: No more SLD translation errors. What you see in QGIS Desktop is exactly what gets served to your web clients (QGIS, Leaflet, OpenLayers, Origo, Lizmap, ArcGIS).
  4. :chart_decreasing: Low Maintenance: No complex XML configurations. It reads your QGIS project file directly.
Capabilities:
  • Dynamic: WMS & WFS
  • Static/Cached: WMTS & XYZ (Directory or MBTiles)
Get started: It requires QGIS Desktop and Node.js.
Happy to answer any questions regarding deployment or performance benchmarks! BR/ Abel
