Good job!!! I'll try this out.
Even if it's only *currently* compatible,
but without you doing almost anything, it's reassuring!!!
Bye Paolo
-----Messaggio originale-----
Da: dblasby@anonymised.com [mailto:dblasby@anonymised.com]
Inviato: mercoledì 7 settembre 2005 17.09
A: geoserver-devel@lists.sourceforge.net
Cc: geotools-devel@lists.sourceforge.net
Oggetto: [Geoserver-devel] Geoserver is *currently* compatible with
geotools 2.1 and 2.2Well, I did a test - I upgraded my Geoserver to use Geotools 2.2. It
looks like there were no problems (I only had to trivially change one
line of a testcase).I'm running CITE tests, and all looks good. Well, since we added the
ability to "plug-in" different output formats and advertise
them in the
capabilities document, CITE has been complaining that our
GetCapabilities responses are not valid, even though they
actually are.
Thats a real pain.... I'll probably add a
"stupid_CITE_conformance_hacks=1" to the config so that it doesnt
advertise its capabilities...But, you can run geoserver with either geotools 2.1.x or 2.2 with no
problems.
AT THIS MOMENT - THERE'S LOTS OF COMMING CHANGING ON TRUNK SO THIS MAY
NOT BE TRUE OVER TIME.
** I dont think anything has really changed on trunk (other than
martin's stuff & he's been very good at keeping things compatible)If you want to try this:
1. check out geotools 2.1.x and geotools trunk
2. "maven build" both
3. make sure your geoserver build.properties points to your maven
repository:
dir.maven=C:\\Documents and Settings\\Owner\\.maven\\repository
On my windows XP machine.
4. in build.xml around like 26 set "version.geotools" to either:
<property name="version.geotools" value="2.1.RC1" />
OR
<property name="version.geotools" value="2.2.x" />
5. Run the "geotools" ant directive (in build.xml)
* this copies all the geotools .jars from your maven repository to
your lib/ directory
6. build & deploy geoserverThings should work normally. Some of the WMS changes are not on
geotools 2.2 (trunk) because we need to make a few decision as to what
the class is going to be called, etc...dave
ps. just to repeat myself 3 times -- just because geoserver is, today,
compatible with 2.1.x and 2.2 (trunk) doesnt mean it will be in the
future.----------------------------------------------------------
This mail sent through IMP: https://webmail.limegroup.com/-------------------------------------------------------
SF.Net email is Sponsored by the Better Software Conference & EXPO
September 19-22, 2005 * San Francisco, CA * Development
Lifecycle Practices
Agile & Plan-Driven Development * Managing Projects & Teams *
Testing & QA
Security * Process Improvement & Measurement *
http://www.sqe.com/bsce5sf
Geoserver-devel mailing list
