raster analysis using real locations? deficiency in mapcalc??
Simon Cox writes:
I want to manipulate a raster map layer where I
apply a polynomial transformation, in which the
coefficients of the polynomial are a (simple) function
of real location. r.mapcalc only appears to know about
relative locations (using the neighbourhood operator).
I can imagine a gruesome technique involving r.stats
and some awk scripts, but there must be a better way.
Can anyone make a suggestion?
This may be a wacky idea, but you could create two additional raster map layers,
one containing northings and the others containing eastings:
  612300 612400 612500 612600 612700 ...
    and
  4173900 4173900 4173900 4173900 4173900 ...
  4173800 4173800 4173800 4173800 4173800 ...
  4173700 4173700 4173700 4173700 4173700 ...
  4173600 4173600 4173600 4173600 4173600 ...
  4173500 4173500 4173500 4173500 4173500 ...
(These would be for a UTM projection with 100 meter resolution.)
These layers could be used to give you absolute coordinates for each cell in
r.mapcalc.
What do you think?
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
