On Tue, Sep 05, 2000 at 10:39:57PM -0500, Rado Bonk wrote:
How do you transfer GRASS5 floating point rasters to integer rasters
readable in GRASS4.3? I accept floating point loosing, since I need to use
SG3d tool in GRASS4.3. How to make them integer before importing them to
GRASS4.3?
Hi Rado,
you can use r.out.ascii and set the number of decimal places
to 0 (dp=0). Then you get an ASCII-Rasterfile. Import this into
GRASS 4.x.
