Back to the original question.
I'd like users to be able to choose to overwrite an existing MASK from the
GUI in r.mask.
AFAICT, this is only possible by making an overwrite flag of some kind in
the script. Currently it is -o (unless someone has changed it). The
system-wide flag --o also causes the script to be in overwrite mode. So what
is the best solution?
1) leave it as is (-o and --o will overwrite the existing MASK). Is this
really a problem?
2) make the flag another letter (Glynn nixed -f)?
3) a different solution that I haven't thought of?
Thanks
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Tue, 3 Oct 2006 14:32:07 +1300
To: Michael Barton <michael.barton@asu.edu>
Cc: <isaac.ullah@asu.edu>
Subject: Re: raster MASKs; was [GRASS-dev] interferring ovewrite flagsYes, you've got it. Glynn has answered on the list better than I could
have, so I'll leave it there.I'm not sure how well any of this is documented; should probably go in
the r.mask help page. Perhaps the GRASS 5 programmers' manual has it
written up nicely already?Hamish
Michael Barton wrote:
OK. Thanks. It took a bit of re-reading this to get it all--and to
connect the dots with your initial post. I think the r.mask script
does not have these issues because it uses r.reclass (like the
original GRASS 5 r.mask did), but it is a good reason for caution when
using r.mapcalc to create a MASK. Just to make sure I've got it, could
you check my comments below?Thanks
Michael
Arizona State Universityphone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbartonFrom: Hamish <hamish_nospam@yahoo.com>
Date: Mon, 2 Oct 2006 20:37:36 +1300
Cc: <grassuser@grass.itc.it>
flagsMichael Barton wrote:
Right. I understand, even if I didn't phrase it that way. Does this
happen for any r.mapcalc processing using the same procedures orjust > ones in which MASK is the result? Also, is it always an "and"
or can > you also get the effects of an "or"? Definitely a 'gotcha'
to watch > out for. I'm concerned especially because we are doing a
lot of > iterative r.mapcalc processing in scripts and this could be
a problem.The MASK is generally applied when a row of input data is read from
the disk.A module scan specifically ask to ignore the MASK, but the vast vast
majority of raster modules process data by row (to save memory), and
use G_get_raster_row() to do that.G_get_raster_row_nomask() is the non-masking version. Things that
use it:
display/d.rast.edit/mk_tmp_file.c
imagery/i.rectify/perform.c
imagery/i.ortho.photo/photo.rectify/perform.c
raster/r.compress/main.c
raster/r.le/r.le.patch/driver.c
raster/r.le/r.le.patch/trace.c
raster/r.le/r.le.pixel/cellclip.c
raster/r.le/r.le.pixel/driver.c
* raster/r.null/null.cThese commands do NOT respect a MASK ???
So:
r.mapcalc MASK='if(isnull(roads))'
r.mapcalc MASK=fields
d.rast elevation.dem # displays with holes
r.mapcalc one=1 # full coverage once MASK is removed
r.mapcalc two=elevation.dem # holes once MASK is removed
g.remove MASK
d.rast one
d.rast twor.mapcalc will respect a MASK ONLY if the formula to create a new map
includes an existing map (i.e., read from disk).A new map created from a formula that does NOT include an existing map
will NOT respect a MASK, even though it may APPEAR to do so when you
display it using d.rast with a MASK in place--because d.rast DOES
respect a MASK.the numeric mapcalc cmd hasn't read a map from the disk, so in fact
it is a solid block. The "two" map has read, so in fact contains
holes. If the "one" map is displayed with a MASK in place, it
appears to have holes in it, but these are introduced when d.rast
loads the map to display it.clear?
I think so.
...From earlier message
"additive" in a processing sense, not mathematical. (still 0|NULL,1)
for example: (spearfish)
MASK created with holes for roads
r.mapcalc reads map "fields", respecting MASK that leaves holes for
roads, and writes new MASK with fields but without roads.d.rast elevation.dem
d.rast respects new MASK that is limited to fields without roads.
shows elevation where there is fields but no roads, as fields is
read in with a mask in place.
