rasterizing digitized contour maps
You should also look at r.surf.contour and s.surf.tps, both methods
of surface construction.
Yes, r.surf.contour looks like what I should be using. I'll
set it to work also.
> 2. I launched r.surf.idw2 yesterday on a SPARC 10,
> and it is still working this morning. The map is
> 834 by 989. How long is this going to take?
It should have been finished by now. Did you make the interpolation
very involved (like using the nearest 24 points) ?
I just went with the default of 12.
Bob Harrington
Hydrology and Water Resources
University of Arizona
