Hi Markus,
Well the problems continue. I made all the changes you suggested but still received the following error message, which on brief glance looks exactly like the message I received before:
if [ ! -d /usr/local/grass-5.0b ]; then mkdir /usr/local/grass-5.0b ; fi
if [ ! -d src/CMD/next_step ]; then mkdir src/CMD/next_step ; fi
UNIX_BIN=/usr/local/bin SRC=`pwd` GISBASE=/usr/local/grass-5.0b MACHINENAME=`una
me -n` /bin/sh src/CMD/generic/CREATE_GMAKE.sh
mkdir -p -m 755 /usr/local/grass-5.0b
/bin/sh `pwd`/src/CMD/generic/is64bit.sh
echo "Now proceed with make install"
GRASSSRC=`pwd`/src GMAKE=`pwd`/src/CMD/gmake5.0 /bin/sh src/CMD/generic/GISGEN.s
h
SRC=/usr/local/grass5.0beta/src
CMD=/usr/local/grass5.0beta/src/CMD
HEADER=head
ARCH=i686-linux-elf
GISGEN Tue Apr 25 19:16:51 PDT 2000
GISBASE = /usr/local/grass-5.0b
SRC = /usr/local/grass5.0beta/src
CMD = /usr/local/grass5.0beta/src/CMD
HEADER = head
ARCH = i686-linux-elf
first step: src/raster/r.binfer
GISGEN: src/raster/r.binfer - Tue Apr 25 19:16:51 PDT 2000
make -f OBJ.i686-linux-elf/make.rules
make[1]: Entering directory `/usr/local/grass5.0beta/src/raster/r.binfer'
rm -f lex.c gram.c
yacc binfer.y
rm -f gram.c
mv y.tab.c gram.c
rm -f OBJ.i686-linux-elf/gram.o
gcc -g -O2 -I/usr/local/grass5.0beta/src/include -c gram.c
mv gram.o OBJ.i686-linux-elf/gram.o
lex binfer.l
rm -f lex.c
mv lex.yy.c lex.c
rm -f OBJ.i686-linux-elf/lex.o
gcc -g -O2 -I/usr/local/grass5.0beta/src/include -c lex.c
binfer.l:41: redefinition of `yylineno'
lex.c:271: `yylineno' previously defined here
make[1]: *** [OBJ.i686-linux-elf/lex.o] Error 1
make[1]: Leaving directory `/usr/local/grass5.0beta/src/raster/r.binfer'
GISGEN failure at STEP: src/raster/r.binfer
make: *** [do-install] Error 1
>> Hi Skip,
>> you find all traps existing in GRASS 5 ![]()
>> This is a problem I had, too, and yesterday I
>> may have found the solution.
>> Store attached file binfer.l in
>> src/raster/r.binfer
>> and proceed with
>> make install
>> Please tell me if compiling now.
>> Thanks
>> Markus
>> On Mon, Apr 24, 2000 at 04:19:05PM -0700, Skip wrote:
>> > Hi Markus,
>> > I installed the flex package as you indicated. Yacc was already
>> installed. However, I still had the compile stop before completing. This
>> is the error message produced:
>> > UNIX_BIN=/usr/bin SRC=`pwd` GISBASE=/usr/local/grass-5.0b
>> MACHINENAME=`uname -n`
>> > h
>> > HEADER=head
>> > ARCH=i686-linux-elf
>> > GISGEN Mon Apr 24 12:41:46 PDT 2000
>> > HEADER = head
>> > GISGEN: src/raster/r.binfer - Mon Apr 24 12:41:46 PDT 2000
>> > rm -f lex.c gram.c
>> > yacc binfer.y
>> > rm -f gram.c
>> > mv y.tab.c gram.c
>> > lex binfer.l
>> > rm -f lex.c
>> > mv lex.yy.c lex.c
>> > >> Hi Skip,
>> > >> > mkdir OBJ.i686-linux-elf
>> > >> > rm -f lex.c gram.c
>> > >> > yacc binfer.y
>> > >> > rm -f gram.c
>> > >> > mv y.tab.c gram.c
>> > >> > lex binfer.l
>> > >> > make[1]: lex: Command not found
>> > >> ... this is easy: just install the "lex/flex" program. Using
>> > >> SuSe use "YAST" to install "flex" and "yacc". lex is a requirement
>> > >> to build GRASS.
>> > >> Then run again
>> > >> configure
>> > >> make install
>> > >> Hope this helps
>> > >> Markus
>> > Skip Haak
>> > Natural Resource Solutions
>> > 950 Lloyd Center, Suite 48
>> > Portland, OR 97232
>> > Office: (503) 460-3198
>> > Mobile: (503) 998-3267
>> > Facsimile: (503) 460-3230
>> > E-mail: shaak@teleport.com
>> Dipl.-Geogr. Markus Neteler * University of Hannover
>> Institute of Physical Geography and Landscape Ecology
>> Schneiderberg 50 * D-30167 Hannover * Germany
>> Tel: ++49-(0)511-762-4494 Fax: -3984
>> -- NextPart --
>> Attached File: c:\goldmine\MailBox\Attach\binfer.l
Skip Haak
Portland, OR 97232
