RE: classy reclass
In response to the question about there being a better way to do the
reclass:
You should have used the non-interactive method of r.reclass:
r.reclass input=original_file output=reclassed_file < reclass_table
Where "reclass_table" is a file that equates the old values to new
values. See the man pages for the syntax. If I were you I would
now use awk to create the next reclass table. Eg., say you want to
divide the original values by 10. Create a file consisting of a list
of the elevation values in your original table (I'll call it
value_list). The syntax using awk would be:
awk '{print S1"="S1/10}' value_list > reclass_table_name
There are snazzier ways of using awk as well.
Erin O'Doherty
USDA Forest Service
Rocky Mtn Forest & Range Exp. Sta.
Laramie WY phone (307) 742-6621
my e-mail address is unfortunately:
/s=e.odoherty/ou=r02f06a/prmd=usda.fs.x400/admd=telemail/c=us/@sprint.
com
(If you need more help with this you could call or e-mail me.)
