RE: d.mon
_______________________________________________________________________________
From: grassu-list@moon.cecer.army.mil on Fri, Dec 16, 1994 16:31
Subject: d.mon
Sender: grass-lists-owner@moon.cecer.army.mil.
Reply-To: grassu-list@moon.cecer.army.mil.
Precedence: Bulk
To: grassu-list@max.cecer.army.mil
I am using grass on a Sun SPSARC5 running Solaris. Recently, I tried
to use "d.mon start=x0". The x0 window is created, but then the GRASS
prompt is not returned. Also, if I control-C to break out, GRASS seems
to think the window is still active.
John
Are sure your .grassrc file is set correctly. You may have made the window
too small. Check it first, it may give you some hint.
