Hi Rob,
am currently trying to organise some effort to get a major
new geotools enhancement (Complex features) into the
Geoserver head, and the WCS support is an obvious target to
try to roll in. Would be grateful if you can identify any
issues, futher development work required to roll that in, and
also if any committed effort for this can be rolled into my
project plan as in-kind support. This sort of in-kind support
will help make the case for the bits of cash we are chasing
to support UI upgrades for the new stuff etc.
Usual story - really want this, but no effort to put in... ![]()
Is there a UI config for the new WCS stuff? If not, what
needs to be done?
If you stick with a small subset (perhaps one) of netCDF conventions you
can imagine a netCDF collection 'scanner' that picks out e.g.
spatiotemporal metadata defined by those conventions across the fileset,
and presents additional configurable options in a GUI. We're working on
this in NERC DataGrid for CSML - rather than geoserver config -
generation.
In general - we have two requirements in the medium term:
1) auto-configure WCS for a catalogue of NetCDF files, to
support subsetting actions easily having found a netCDF file
in a catalogue
In most atmos/ocean use cases you don't want file-level discovery. You
want the aggregated (timeseries) dataset.
2) be able to subset (in a single WCS call) from collections
of netCDF files across both spatial and temporal dimensions.
Yep.
Also, there are many netCDF conventions - what is the
expected level of support and configurability?
The 'CF' conventions for atmos/ocean data are the canonical standard:
http://www.cgd.ucar.edu/cms/eaton/cf-metadata/CF-1.0.html
though (as far as I'm aware) not implemented in full *anywhere*.
However, an incremental approach can be taken - e.g. starting with
independent spatiotemporal coord vbls
(http://www.cgd.ucar.edu/cms/eaton/cf-metadata/CF-1.0.html#grid_ex1),
then sorting 'auxiliary coord vbls'
(http://www.cgd.ucar.edu/cms/eaton/cf-metadata/CF-1.0.html#grid_ex2)
etc... A large amount of deployed met/ocean netCDF is covered by a small
subset of CF.
