RE: [Geoserver-users] v1.3.0
Congratulations on 1.3 release!
I’ve downloaded 1.3 as a .war deployed to Tomcat 5.5.12 on Windows 2003.
Here is some feedback:
  1. On initial start up there were a series of logged warnings and errors.
WARNING: Could not aquire PostGIS spatial database:org.geotools.data.DataSourceException: Connection failed:org.postgresql.util.PSQLException: A connection error has occurred: org.postgresql.util.PSQLException: FATAL: password authentication failed for user “postgres”
I believe it is expecting to connect to a PostGIS with a generic password using the datastore definition for a localPostGIS:
Namespace: topp
Db: dcmms
If I edit the localpostgis datastore or delete and redeploy the errors no longer occur…
Followed by a series of Severe events like:
SEVERE: Attempting to create file:D:\Apache Software Foundation\Tomcat 5.5\webapps\geoserver\data\plugIns\Gazetteer.xml
Jan 27, 2006 10:11:35 AM org.vfny.geoserver.global.xml.XMLConfigWriter$WriterUtils initFile
These also disappeared after removing the datastore for localPostGIS
In addition
java.lang.IllegalAccessException: Class org.vfny.geoserver.servlets.FreefsLog can not access a member of class org.geotools.data.arcsde.ConnectionPoolFactory with modifiers “public static synchronized”
I wonder if there is a default arcsde lurking in the datastores? There it is ‘testSDE’ This probably won’t work for a generic deployment.
  1. I noticed a z3950-geo.map file. Does 1.3 have a z3950 catalogue service?
  2. I notice the Server config: write logs to file logs/geoserver.log doesn’t appear to work even when enabled?
Now after a couple of Tomcat restarts it is working? But after the next restart it no longer works again?
  1. demos.
WMS Example works great!
Previews most work very well big improvement from previous version!
tiger:tiger_roads is blank?
tiger:giant_polygon is blank
Sample Request
WFS describefeaturetype.xml etc
WARNING: OutputStream could not be aborted in time. An error has occurred and could not be sent to the user.
Jan 27, 2006 2:30:46 PM org.vfny.geoserver.servlets.AbstractService init
INFO: Set buffer size to 50
Jan 27, 2006 2:30:46 PM org.vfny.geoserver.servlets.AbstractService sendError
INFO: Had an undefined error: null
·862641 [WARNING] org.vfny.geoserver.util.requests.XmlCharsetDetector - Invalid(?) XML declaration: <!-- A.
Also
        org.vfny.geoserver.wfs.servlets.TestWfsPost.processRequest(TestWfsPost.java:236)
        org.vfny.geoserver.wfs.servlets.TestWfsPost.doPost(TestWfsPost.java:68)
Note that http://localhost/geoserver/wfs/GetCapabilities works fine just not the TestWfsPost post body? Perhaps I am missing a required library?
I am downloading the current svn for TestWfsPost 1.3 to see where I’m in trouble.
  1. One last question what is status of ComplexDatastore? Will that be available in the 1.4 release?
Thanks
randy
Hi Randy
Randy George wrote:
Thanks !!
            I've downloaded 1.3 as a .war deployed to Tomcat 5.5.12 on
Windows 2003.
1) On initial start up there were a series of logged warnings and errors.
user "postgres"
Namespace: topp
Db: dcmms
longer occur..
In addition
org.geotools.data.arcsde.ConnectionPoolFactory with modifiers "public static
synchronized"
'testSDE' This probably won't work for a generic deployment.
Thanks for the feedback, this got missed despite Chris reminding me about it :). I plant to fix this and upload a new 1.3.0. Good thing i havent made the official announcement yet :slight_smile:
2) I noticed a z3950-geo.map file. Does 1.3 have a z3950 catalogue service?
Kind of, its not really maintained, we pretty much just tell people to use geonetwork, they have the real deal.
3) I notice the Server config: write logs to file logs/geoserver.log doesn't
4) demos.
version!
            Sample Request
sendError
.862641 [WARNING] org.vfny.geoserver.util.requests.XmlCharsetDetector -
Hmm, i am going to have to take a look at these a little closer.
Also
236)
Note that <http://localhost/geoserver/wfs/GetCapabilities&gt;
I am downloading the current svn for TestWfsPost 1.3 to see where I'm in
trouble.
5) One last question what is status of ComplexDatastore? Will that be
Yup, its pretty much the focus of the 1.4 stream of development.
Thanks
randy
Thanks Randy, this feedback has been great!!
-Justin
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
