RE: [GRASS-dev] RE: [GRASS-user] Error importing DMS into standar dformat usingv. in.ascii
Ok, I finally got my points imported with this command:
echo "B 5 1
66.5 44.0
66.5 44.25
66.0 44.25
66.0 44.0
66.5 44.0
1 1" | v.in.ascii -n output=new_test format=standard
Note that the field separator is a space, but v.in.ascii is not explicitly
told so using the fs= parameter, which is kind of odd.
~ Eric.
-----Original Message-----
To: 'Markus Neteler '; '''grassuser@grass.itc.it' ' ';
'''grass-dev@grass.itc.it' ' '
Sent: 9/27/2006 11:43 AM
Subject: RE: [GRASS-dev] RE: [GRASS-user] Error importing DMS into
standardformat usingv. in.ascii
Again, it fails even if W and N are omitted:
echo "66.5|44.25" | v.in.ascii -n output=DMS_test format=standard --o
Error reading ascii file:
66.5|44.25
Building topology ...
0 primitives registered
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built.
Number of nodes : 0
Number of primitives: 0
Number of points : 0
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
I tried reversing Long and Lat, but get the same error. Interestingly,
the
"Error reading ascii file" line disappears if I run the same command
without
the -n flag, but still fails:
echo "66.5|44.25" | v.in.ascii output=DMS_test format=standard --o
0 areas built
0 isles built
Attaching islands:
Number of nodes : 0
Number of lines : 0
Number of areas : 0
Number of isles : 0
To: ''grassuser@grass.itc.it' '; ''grass-dev@grass.itc.it' '
Sent: 9/27/2006 11:29 AM
Subject: Re: [GRASS-dev] RE: [GRASS-user] Error importing DMS into
I think that decimal degree go without W and N since
the minus is used for West/South.
On Wed, Sep 27, 2006 at 12:18:54PM -0300, Patton, Eric wrote:
Trying again after converting DMS to deciaml degrees:
echo "L 4 1
66.5W|44.25N
66.0W|44.25N
66.0W|44.0N
66.5W|44.0N
1 1 " | v.in.ascii -n output=DMS_test format=standard --o
66.5W|44.25N
0 areas built
0 isles built
Attaching islands:
Number of nodes : 0
Number of lines : 0
Number of areas : 0
Number of isles : 0
The above command also fails if the coodinates are given to 6 decimals
places, which probably doesn't even matter.
~ Eric.
grass-dev mailing list
echo "B 5 1
66.5 44.0
66.5 44.25
66.0 44.25
66.0 44.0
66.5 44.0
FWIW, feeding sizeable amounts of literal text to a command's stdin is
best done using a "here document" rather than using "echo", e.g.:
v.in.ascii -n output=new_test format=standard <<EOF
B 5 1
66.5 44.0
66.5 44.25
66.0 44.25
66.0 44.0
66.5 44.0
1 1
EOF
The fs= option only applies to format=point. Actually, most of the
options only apply to format=point.
v.in.ascii is essentially two different programs in one; format=point
and format=standard have very little in common.
echo "B 5 1
66.5 44.0
66.5 44.25
66.0 44.25
66.0 44.0
66.5 44.0
fyi, usually boundaries don't have category number.
e.g. two parcels of land next to each other, which "owns" the boundary?
It's ok if the boundary is something like a road.
add a centroid in the input or add later with v.centroids.
explicitly told so using the fs= parameter, which is kind of odd.
the "standard" format is explicit. Sorry if that is unclear in the options.
Hamish
