(sorry, attached this time)
-mpg
-----Original Message-----
From: Michael P. Gerlek [mailto:mpg@lizardtech.com]
Sent: Wednesday, June 07, 2006 5:11 PM
To: dev@visibilitycommittee.osgeo.org
Subject: RE: [VisCom] OSGeo Presentation Template - Draft -
Review and Comment by Tues 6/6Using Perry's template, I dumped some (DRAFT!) content into it -- it
looks ok, but somehow seems lacking in color. See attached.(Note I had to punt on the PowerPoint conversion as things came out
kinda weird, and I had some Issues with Impress not laying things out
the way I like them to, but it's a start.)I'm thinking about playing with the following sorts of tweaks:
1- a thin, clean green line below the title line?
2- introduction of a new color to the pallette, to be
used for body text (where we want to set something
off from the default black)3- 1st-level bullets should be green; maybe slightly
different shades of green as we nest in deeper?4- the "section" slide definitely needs another visual
element -- maybe the "thin green line" from above
could play in here too?5- I'm not sure I like the font -- a little too sans for
my tastes?6- could the Giant Background Wheel be positioned on the
right side, instead of the left? This might make it
clash less with the left-justified body text [unless
you're doing content with one of those right-to-left
alphabets...]Also, there was an Autodesk copyright on the master, which I removed.
I might play with this some more over the weekend and see what I can
come up with... but in any case, it's a great start and perfectly
usable for Where as is.-mpg
To unsubscribe, e-mail: dev-unsubscribe@visibilitycommittee.osgeo.org
For additional commands, e-mail:
dev-help@visibilitycommittee.osgeo.org
OSGeo-GeoWeb - new.odp (111 KB)
