For the past week or so, I've been 'approving' things as soon as they
come in. (maybe I should just learn to add someone to the approved-list
or something...)
-mpg
-----Original Message-----
From: Arnulf Christl [mailto:arnulf.christl@ccgis.de]
Sent: Wednesday, March 15, 2006 9:42 AM
To: dev@visibilitycommittee.osgeo.org
Subject: [VisCom] Re: FW: MODERATE for
dev@visibilitycommittee.osgeo.orgMichael P. Gerlek wrote:
> Ummm... I saw Markus' post go through -- presumably someone did the
> 'approval'?
> -mpgSomeone was me. Was it wrong? Who else is someone and can approve? I
would like to share this reponsibility, else people will have to wait
until i find these mails in my inbox and you don't want to see what
currently is going on there...> -----Original Message-----
> From:
dev-reject-1141409874.32000.gbdefnahacoelggdpmja@visibilitycom
mittee.osg
> eo.org
[mailto:dev-reject-1141409874.32000.gbdefnahacoelggdpmja@visib
ilitycommi
> ttee.osgeo.org]
> Sent: Friday, March 03, 2006 10:18 AM
> Cc:
dev-allow-tc.1141409874.ilalejkjdgafcphgpeeb-neteler.osgeo=gma
il.com@vis
> Subject: MODERATE for dev@visibilitycommittee.osgeo.org
> The enclosed message was submitted to the
> mailing list. If you'd like to approve it for distribution to all
> the subscribers, please e-mail:
dev-accept-1141409874.32000.gbdefnahacoelggdpmja@visibilitycom
mittee.osg
> eo.org
> Usually, this happens when you just hit the "reply" button. You can
> check the address to make sure that it starts with
> "dev-accept". If this does not work, simply copy the
> address and paste it into the "To:" field of a new message.
> To reject the post and cause it to be returned to the
> sender, please send a message to:
mittee.osg
> eo.org
> Usually, it is easiest to hit the "reply-to-all" button, and then
> remove all the addresses except the one starting with
> "dev-reject".
> You do not need to copy the post in your response to accept or
> reject it. If you wish to send a comment to the sender of a rejected
> post, please include it between two marker lines starting with three
> percent signs ('%'):
> %%% Start comment
> %%% End comment
> Thank you for your help!
> --- Enclosed, please find the posted message.
> Subject:
> test only MN
> From:
> "Markus Neteler" <neteler.osgeo@gmail.com>
> Date:
> Fri, 3 Mar 2006 10:17:52 -0800
> To:
> "OSGeo VisibCom" <dev@visibilitycommittee.osgeo.org>
> To:
> Hi,
> not sure if I receive mails here...
> Markus
> To unsubscribe, e-mail:
dev-unsubscribe@visibilitycommittee.osgeo.org
> For additional commands, e-mail:
dev-help@visibilitycommittee.osgeo.org---------------------------------------------------------------------
To unsubscribe, e-mail: dev-unsubscribe@visibilitycommittee.osgeo.org
