Rebuild of Docker Images to fix Java4Shell for Geoserver (+Cloud) (and Geonetwork)
I guess Geoserver Docker Images are vulnerable for CVE-2026-114938:
https://nvd.nist.gov/vuln/detail/cve-2026-114938
Will there be a rebuild of relevant images to fix this security issue?
Regards
Marco
Hi @mlechner and welcome to the user forum :slight_smile:
There are mitigation instructions here including for Docker:
  • Official GeoServer Docker image (docker.osgeo.org/geoserver): add -e JAVA_TOOL_OPTIONS=-XX:-UseBASE64Intrinsics to docker run.
We are presently waiting on release of JDK patches (looks like they are being built still).
And then yes it would be good to rebuild the latest three releases. I would like to check with @Peter who has been helping getting simultaneous amd64 and arm64 images published.
Any news on the rebuild of relevant Images?
https://docker.osgeo.org/#browse/browse:docker:v2%2Fgeoserver%2Ftags%2F2.28.6 and
https://docker.osgeo.org/#browse/browse:docker:v2%2Fgeoserver%2Ftags%2F3.0.2 are still from 10-2026 an people go on downloading (and running) vulnerable Images.
Regards
Marco
@mlechner As you can see in November 2026 Release Status per Platform, Version & Binary Type · Issue #326 · adoptium/temurin · GitHub and Eclipse Temurin guidance for CVE-2026-114938 "java4shell" | Adoptium The world is waiting for a release of a fixed java runtime, as documented the actual problem is easily avoided after reading the documentation and instructions which anyone running any service on the internet should do for starters
