Refinement of r.horizon Output
Hello, first post, please bear with me.
I recently used r.horizon to generate horizon elevation vs. azimuth relative to a specified surface point on a DEM raster. Is there any way to also get output for the actual coordinates of the calculated horizon point at each azimuth? I presume the calculation must generate these coordinates (or their equivalent) at some point in order to obtain elevation angle… can they be extracted during or after the fact? Thanks for any info!
