Hi all
@aaime-geosolutions @jive @tbarsballe
About cite-geoserver:
From this: #150922 I suppose I can continue on the movement from osgeo3 to osgeo8
On osgeo8 I created the certificates, for cite.geoserver.org and g1 to g7 of *.cite.geserver.org
For example this g1.cite.geoserver.org
When using osgeo3:
When using osgeo8:
If I do a ping:
Hi all
When using osgeo3:
When using osgeo8:
If I do a ping:
ping g1.cite.geoserver.org
PING web.osgeo8.osgeo.org (140.211.15.9) 56(84) bytes of data.
64 bytes from osgeo8.osgeo.osuosl.org (140.211.15.9): icmp_seq=1 ttl=52 time=79.1 ms
64 bytes from osgeo8.osgeo.osuosl.org (140.211.15.9): icmp_seq=2 ttl=52 time=77.8 m
I noticed that there is a docker on osgeo3:
docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
530983e6a73f geoserver-docker.osgeo.org/geoserver:2.27.0 “bash /opt/startup.sh” 4 months ago Up 4 months (healthy) 0.0.0.0:8082->8080/tcp, \[::\]:8082->8080/tcp cite_geoserver-wfs20_1
d15d252225af geoserver-docker.osgeo.org/geoserver:2.27.0 “bash /opt/startup.sh” 4 months ago Up 4 months (healthy) 0.0.0.0:8083->8080/tcp, \[::\]:8083->8080/tcp cite_geoserver-wfs11_1
15ac5f40a914 geoserver-docker.osgeo.org/geoserver:2.27.0 “bash /opt/startup.sh” 4 months ago Up 4 months (healthy) 0.0.0.0:8081->8080/tcp, \[::\]:8081->8080/tcp cite_geoserver-wms_1
29067038b636 geoserver-docker.osgeo.org/geoserver:2.27.0 “bash /opt/startup.sh” 4 months ago Up 4 months (healthy) 0.0.0.0:8086->8080/tcp, \[::\]:8086->8080/tcp cite_geoserver-wcs10_1
358c1830a413 geoserver-docker.osgeo.org/geoserver:2.27.0 “bash /opt/startup.sh” 4 months ago Up 4 months (healthy) 0.0.0.0:8085->8080/tcp, \[::\]:8085->8080/tcp cite_geoserver-wcs11_1
8ea756258b04 geoserver-docker.osgeo.org/geoserver:2.27.0 “bash /opt/startup.sh” 4 months ago Up 4 months (healthy) 0.0.0.0:8087->8080/tcp, \[::\]:8087->8080/tcp cite_geoserver-gpkg12_1
2a6b74841a20 postgis/postgis:17-3.5 “docker-entrypoint.s…” 4 months ago Up 4 months (healthy) 0.0.0.0:5555->5432/tcp, \[::\]:5555->5432/tcp cite_postgres_1
But docker is not running on osgeo8
docker ps
In the notes about the setup of cite-geoserver there is nothing about how to start docker
Let me know when done
Right now I have DNS pointing to osgeo8, Please can someone start docker properly
I will turn it back to osgeo3 in about an hour, which will be shut down soon, which makes the osgeo8 starting docker urgent.
Regards
Vicky
