Hello all,
I’m working on useing the RestAPI to fill our Instances with content, e.g. create new featureTypes or chage a Style.
Due to that I have found that the Styles endpoint sometimes returns a 200 statuscode but dose not apply all changes to the sld-file on the server.
For Example this sld is on the server
<?xml version="1.0" encoding="UTF-8"?><sld:StyledLayerDescriptor xmlns:sld="http://www.opengis.net/sld" xmlns="http://www.opengis.net/sld" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" version="1.0.0">
<sld:NamedLayer>
<sld:Name>A_Test</sld:Name>
<sld:UserStyle>
<sld:Name>Default Styler</sld:Name>
<sld:Title>dark yellow square point style</sld:Title>
<sld:FeatureTypeStyle>
<sld:Name>name</sld:Name>
<sld:Rule>
<sld:Title>dark yellow point</sld:Title>
<sld:PointSymbolizer>
<sld:Graphic>
<sld:Mark>
<sld:Fill>
<sld:CssParameter name="fill">#000000</sld:CssParameter>
</sld:Fill>
</sld:Mark>
<sld:Size>6</sld:Size>
</sld:Graphic>
</sld:PointSymbolizer>
</sld:Rule>
</sld:FeatureTypeStyle>
</sld:UserStyle>
</sld:NamedLayer>
</sld:StyledLayerDescriptor>
Changing the <sld:Name> under <sld:NamedLayer> local and then send it as body of a Put Request dose not update the line <sld:Name> on the Server. The staus code of the Response is 200. Chaning the the value of the color works. Using the webui I can change the line <sld:Name>, therefore I asume this is behaviore is not intendet.
On a similar node the Styles enpoint only works when the accept Header is “plain/text” or not pressent. Is this intendet? Cause as far as I see it every other endpoint can return “application/json” and “application/xml”.
