Hello Fellow Grassmates ,
When I run grass4.1 as user: grass ,I am allowed to create and use only
mapset named 'grass' .If I try to create another mapset ,the system
simply hangs in GIS.sh while executing gis_set ...
When recompiling grass on the HP's ,I found that the binaries lex and
yacc were missing on the system ...After putting in the binaries ,the
above problem still persists ..
Also ,if I login as an ordinary user ,I cannot create the mapset grass
itself in my $HOME...
I am using Grass v4.1
Your help is appreciated!
Thanks!
Ian D'Abreo
