The continue stmt in question is in a loop. It prevents the code which folows
from being executed. I could have used and if-else, but I prefer this
semantic when I can use it.Michael
but the "continue;" is in an "if" statement not a loop...the interpolation
routines are outside this "if" statement so doesn't the continue just
jump out of the if and do the interpolation? I'm not myself if this is
a serious question, because I have used s.surf.idw and it works...unless
there are actually values under the mask...I have never checked...
chris
|\/\/\/| Chris Skelly
| | School of Earth Sciences
| | High expolsives and Macquarie University
| (o)(o) school do NOT mix. North Ryde, 2109, NSW, OZ
C _) Tel: 612-805-8433
| ,___| Fax: 612-805-8428
| / chris@mqclimat.cic.mq.edu.au
