I wonder why we're having a GIT binary package installed on the TracSVN VM
which causes broken dependencies.
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
Rather than building it manually I downloaded a .deb package from
a newer Debian distribution. Feel free to revert to the official
packages if you think it'll be safer (I migth not be able for the next month):
it was "git" and "bash-completions" that I installed that way.
I didn't mean to revert the GIT package (because then I'm responsble for
fixing the Gitea stuff which I know very little about and moreover I
don't generally object against installing packages from compatible distros.
But if we do so, then I'd prefer not to forcibly break dependencies - as I
wrote earlier - but instead properly install the required packages as well.
Martin.
On Wed, Nov 01, 2017 at 01:24:26PM +0000, Martin Spott wrote:
> My fault, git-1.8 was needed for Gitea-1.2:
> https://github.com/go-gitea/git/pull/48
I didn't upgrade Gitea anymore so the old packages would not break
anything.
and moreover I
I'm a big lame when it comes to do this part of the work.
Maybe "aptitude" would be smart enough to do it on its own, what do
you think ? Isn't it fun to be stuck on a Debian old-old-old-stable ?
PS: your name often comes out as "the one and only capable of
upgrading distributions on osuosl VMs"... is that true ?
anything.
Ok, I've reverted the "git" package to the one shipped with the distro.
I don't know, but maybe I'm the only one who tried
Martin.
because you have console access?
No, not at all, I used a regular root shell to run these dist-upgrades.
Every primary admin could do so as well.
Martin.
On Sun, Nov 05, 2017 at 11:19:45PM +0100, Jürgen E. Fischer wrote:
Hi Martin,
You don't have console access?
If the dist-upgrade includes a kernel upgrade and a reboot I'd be uncomfortable
w/o console access in case the boot fails...
Indeed, but I think you can synchronize with people in #osuosl
to request their intervention in case of drama. They are friendly !
--strk;
+1 coordinate with #osuosl
There is however a non standard part of the upgrade process that Martin
figured out at some point, related to the boot partition. I think more
people are capable of it if we understood what needs to be done.
