Ah, this is the email, missed that one of them came to osgeo.
The solution is to upgrade certbot to at least 0.28 I believe, then it will use a newer method to authenticate.
Alex
-------- Forwarded Message --------
Subject: Action required: Let's Encrypt certificate renewals
Date: Fri, 18 Jan 2019 03:33:24 +0000
To: sysadmin@osgeo.org
Hello,
**Action is required to prevent your Let's Encrypt certificate renewals from breaking.**
Your Let’s Encrypt client used ACME TLS-SNI-01 domain validation to issue a certificate in the past 60 days.
TLS-SNI-01 validation is reaching end-of-life and will stop working on **February 13th, 2019.**
You need to update your ACME client to use an alternative validation method (HTTP-01, DNS-01 or TLS-ALPN-01) before this date or your certificate renewals will break and existing certificates will start to expire.
If you need help updating your ACME client, please open a new topic in the Help category of the Let's Encrypt community forum:
https://community.letsencrypt.org/c/help
Please answer all of the questions in the topic template so we can help you.
For more information about the TLS-SNI-01 end-of-life please see our API announcement:
Thank you,
Let's Encrypt Staff
