I have taken the liberty of configuring Bacula this morning on the backup.osgeo.org
VM. Bacula is now configured with a Storage Device in /backup/bacula on that machine,
and a job configured to backup a file (/osgeo/trac_backup.sh) from trac.osgeo.osuosl.org.
The file is created by /osgeo/backup.sh, which is set in cron to run every morning at
1:37AM, via root's crontab.
The backup command takes about 90 seconds to run, and does a hotcopy of each trac
environment, followed by a pg_dump of the corresponding database to a file, then
zipping the result up. The zip file is ~500MB, and currently it is set to be
removed after 2 days. (So we will have 1GB of trac backups. I think.)
I have also tested restoring from bacula; the following steps:
sudo bconsole
restore
5 (Select the most recent backup for a client)
2 (trac.osgeo.osuosl.org-fd)
add /osgeo
done
yes
After approximately two minutes, the zipfile was restored to:
/backup/bacula/osgeo/trac_backup.zip
on the trac server.
To add more backups to the Bacula system, we should be able to do something
similar to this for each host:
Job {
Name = "BackupTrac"
Level = Full
FileSet = "TracFile"
Type = Backup
Schedule = TracSchedule
Storage = File
Where = /backup/bacula/trac
Pool = Default
Messages = Standard
Client=trac.osgeo.osuosl.org-fd
FileSet {
Name = "TracFile"
Include {
File = /osgeo/trac_backup.zip
Schedule {
Name = "TracSchedule"
Run = Full sun-sat at 2:03
Client {
Name = trac.osgeo.osuosl.org-fd
Address = 140.211.15.71
FDPort = 9102
Catalog = MyCatalog
Password = "blahblah" # password for FileDaemon 2
File Retention = 3 days # 30 days
Job Retention = 6 months # six months
AutoPrune = yes # Prune expired Jobs/Files
This is pulled directly from /etc/bacula/bacula-dir.conf.
I don't know much about Bacula, so there may be problems I've
created here. I have not implemented any partial/incremental backup
strategy at this time. (I'm not really sure how I'd do it for
trac anyway.)
Combined with the existing SVNMirror infrastructure, I believe
that this completes the task of backing up the important aspects of
the Trac/SVN server.
Christopher Schmidt
Nokia
