I found out that all the bayes training was having no effect
after looking at the actual database tables. Enabling DEBUG
level logging I found the spambayes module was missing (dunno
why it wasn't printed to INFO or WARNING).
Installing spambayes (pip install) fixed the issue, so now
your spam training will actually _do_ something. It'll take
25 ham and spam entries before it's used to score submissions.
Are you referring to spam filtering in OSGeo Trac Wiki ?
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
I'm referring to spam filtering in OSGeo Trac (not just wiki
but also tickets). Sorry for not having mentioned it before.
Basically when some dependencies are missing for a plugin to work,
a simple DEBUG message is sent to logs (if enabled) but in this
case the failure did not prevent including bayes-related settings
in the web admin interface, so it wasn't at all clear that
something was not working
Now you can tell if it's working or not by looking at the top of
the {Spam Filtering/Bayes} page. For example:
Currently mentions: "The training database currently contains 0 spam
and 11 ham submissions". It takes a minimum of 25 submissions to start
scoring content (per current global configuration, unchanged from the
default).
