Hello,
I am having issues accessing:
https://download.osgeo.org/webdav/geotools/ (and https://download.osgeo.org/)
HTTP works fine, but not HTTPS. HTTPS appears to run into an SSL protocol error.
https://www.geotools.org/ serves a cert with *.osgeo.org as the common name. This cert would work for download.osgeo.org, so it looks like all the pieces are in place to enable https.
Is there a chance someone could fix SSL for download.osgeo.org?
Thanks!
I also noticed the following:
- geotools.org does not appear in the Common Name or the Subject Alternate Name for the cert referenced above, thus this cert cannot be used to verify the identity of www.geotools.org
- The cert referenced above expires Sunday, May 1, 2016, which is in less than a month
Alex
