Error while processing /etc/awstats/awstats.conf
Create/Update database for config "/etc/awstats/awstats.conf" by AWStats version 7.0 (build 1.971)
From data in log file "/var/log/apache2/access.log"...
Error: Couldn't open server log file "/var/log/apache2/access.log" : No such file or directory
Setup ('/etc/awstats/awstats.conf' file, web server or permissions) may be wrong.
Check config file, permissions and AWStats documentation (in 'docs' directory).
No need for a ticket. This is coming from tracsvn-dev on osgeo4 which is a 9/5/2019 snapshot image of trac-svn. I shut of the cron job after.
Though I am puzzled it was erroring at all. I will check before we do a final move of track.
-----Original Message-----
From: Sac [mailto:sac-bounces@lists.osgeo.org] On Behalf Of Alex Mandel
Sent: Wednesday, September 11, 2019 11:45 AM
To: System Administration Committee Discussion/OSGeo <sac@lists.osgeo.org>
Subject: [SAC] Fwd: Cron <www-data@tracsvn-dev> [ -x /usr/share/awstats/tools/update.sh ] && /usr/share/awstats/tools/update.sh
Error while processing /etc/awstats/awstats.conf Create/Update database for config "/etc/awstats/awstats.conf" by AWStats version 7.0 (build 1.971) From data in log file "/var/log/apache2/access.log"...
Error: Couldn't open server log file "/var/log/apache2/access.log" : No such file or directory Setup ('/etc/awstats/awstats.conf' file, web server or permissions) may be wrong.
directory).
Sac mailing list
Sac@lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/sac
