So based on Bacula setting here's what's currently configured.
Backup files are stored on Backup.osgeo under /backup/bacula and are
retrievable via Bacula. There's currently 109GB of backed up files.
This consists of the following directories:
File = /boot
File = /etc
File = /var/www
File = /osgeo
File = /var/lib/mysql
File = /var/lib/postgresql
File = /var/lib/dpkg
File = /var/lib/aptitude/pkgstates
A Full copy is made every Sat. with incremental backups nightly.
Combined with the Rsync clone of Download we are at
/dev/vdb1 500G 197G 304G 40% /backup
disk usage.
So the next logical step is to get scripts written that dump important
databases to the file system. We can either put them into /osgeo folders
on each server to have them picked up by the current system or put them
at a different path and configure a different job specific to picking up
people db dumps. Technically mysql and postgres appear to be picked up
but that's not in a format that's transportable to other servers.
Note these scripts can be set to run from Bacula, here's an example from
tracsvn:
Client Run Before Job = /osgeo/backup.sh
Client Run After Job = "rm /osgeo/trac_backup.zip"
Hopefully that gives everyone enough info to think about the next steps.
I am using the following link to see the download statistics for download.osgeo.org: http://download.osgeo.org/cgi-bin/awstats.pl? and it appears that it has not been updated since Sept 2010. Do I have the correct link for download stats, or is there a problem with the awstats cron job on that machine?
On Wed, Jan 26, 2011 at 4:19 PM, Jeff McKenna
that machine?
I would be able to check but have no longer a login on that machine.
that machine?
Markus,
Access to download.osgeo.org should be based on the "telescience" ldap
group which you are in. I have logged in and giving you sudo access as
well.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Programmer for Rent
