Since the upgrade I've started getting Deny Hosts notifications from
Trac machine. See below; we should probably be sending these to the
sysadmin address, and maybe cleaning up the send info, it wasn't clear
where this was coming from until I read the full source header.
I assume you fixed the cron message about awstats?
Alex
-------- Forwarded Message --------
Return-Path: <nobody@localhost>
Received: from [74.208.5.3] ([74.208.5.3]) by mx.perfora.net (mxeueus004
[74.208.5.3]) with ESMTPS (Nemesis) id 0M9Hce-1ew6bp2SeU-00ClKi for
<tech_dev@wildintellect.com>; Fri, 16 Feb 2018 17:51:11 +0100
Received: from lists.osgeo.org ([140.211.15.3]) by mx.perfora.net
(mxeueus004 [74.208.5.3]) with ESMTPS (Nemesis) id
0LchtJ-1eKZrs2Pot-00kALR for <tech@wildintellect.com>; Fri, 16 Feb 2018
17:51:11 +0100
Received: by lists.osgeo.org (Postfix) id D8D4A6146838; Fri, 16 Feb 2018
08:51:10 -0800 (PST)
Delivered-To: sysadmin@osgeo.org
Received: from trac.osgeo.org (tracsvn.osgeo.osuosl.org [140.211.15.71])
by lists.osgeo.org (Postfix) with ESMTP id D6D72614681E for
<sysadmin@osgeo.org>; Fri, 16 Feb 2018 08:51:10 -0800 (PST)
Received: by trac.osgeo.org (Postfix) id CA522390101; Fri, 16 Feb 2018
Delivered-To: root@localhost
Received: from git.osgeo.org (localhost [127.0.0.1]) by trac.osgeo.org
(Postfix) with ESMTP id C556F3900FF for <root@localhost>; Fri, 16 Feb
To: root@localhost
Subject: DenyHosts Report
Date: Fri, 16 Feb 2018 08:51:10 -0800
Message-Id: <20180216165110.C556F3900FF@trac.osgeo.org>
Envelope-To: <tech_dev@wildintellect.com>
X-UI-Filterresults:
notjunk:1;V01:K0:YQ3P3OPt2fw=:kiMqfhezE4wIZjOyZZLajz1HwN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Added the following hosts to /etc/hosts.deny:
46.10.150.75 (46-10-150-75.ip.btc-net.bg)
