As we found out that _DELETING_ a spam wiki page was also being
considered "offensive" by my fail2ban recipe, I disabled it
for the trac-spam checking.
Contextually, I've made sure TracSpamPlugin is enabled in each
and every instance, so from now on spam filtering should be dealth
with via the admin panel of each instance.
On May 7, 2016 3:57 PM, “Sandro Santilli” <strk@keybit.net> wrote:
Contextually, I’ve made sure TracSpamPlugin is enabled in each
Thanks. Is there any action item related to this for trac admins?
The action is: configure the filter.
Unfortunately the configuration is per-instance so cannot be shared.
I've been playing a bit with ossim as it was under attack.
The default configuration doesn't catch much spam, especially as
the score of being authenticated is very high (20). Not many systems
allow spammers to register accounts (fixing the LDAP registration
is top priority to reduce spam). The score of various filters can
be set via https://trac.osgeo.org/INSTANCE/admin/spamfilter/config
These activities can by default only be done by those who
have TRAC_ADMIN permission, but the plugin adds also spamfilter
specific permissions you could use to grant more power to
others. Details here: https://trac.edgewall.org/wiki/SpamFilter#Permissions
If someone would write these various things on a wiki page and link
the new page from Trac_Instances it would be helpful.
