Gwenael, it looks like someone has already addressed this (the page is working, anyways). In future, it’s probably best to put in a Trac ticket with the component set to SAC (systems administration committee) at:
I think that display_errors should probably be turned off in the php.ini file. Hackers can make use of that kind of error reporting for finding and exploiting vulnerabilities.
Jason
From: Gwenael Bachelot [mailto:gwenael.bachelot@eur.autodesk.com]
Sent: Thursday, July 31, 2008 05:42
To: webcom@lists.osgeo.org
Subject: Error message on MapGuide Open Source - OSGeo
Hi list,
There’s the following error message on the page MapGuide Open Source - OSGeo :
user warning: Table ‘./drupal_mapguide/accesslog’ is marked as crashed and should be repaired query: INSERT INTO accesslog (title, path, url, hostname, uid, sid, timer, timestamp) values(‘MapGuide Project Home’, ‘node/56’, ‘’, ‘132.188.32.100’, 0, ‘d62807df4dc5cf2012a984f6716904ed’, 222, 1217499957) in /var/www/html/includes/database.mysql.inc on line 172.
Cordialement,
Gwenael Bachelot
Gwenael Bachelot - Mailto:gwenael.bachelot@autodesk.com
http://blogs.autodesk.com/geospatialfrance
Direct :+33(0)1.46.46.38.77 - Mobile : +33(0)6.26.62.18.61
