When attempting to login to GDAL trac, I get:
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 387, in
dispatch_request
dispatcher.dispatch(req)
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 237, in
dispatch
resp = chosen_handler.process_request(req)
File "/usr/lib/python2.3/site-packages/trac/web/auth.py", line 100, in
process_request
self._do_login(req)
File "/usr/lib/python2.3/site-packages/trac/web/auth.py", line 139, in
_do_login
"VALUES (%s, %s, %s, %s)", (cookie, remote_user,
File "/usr/lib/python2.3/site-packages/trac/db/util.py", line 50, in
execute
return self.cursor.execute(sql_escape_percent(sql), args)
File "/usr/lib/python2.3/site-packages/sqlite/main.py", line 237, in
execute
self.con._begin()
File "/usr/lib/python2.3/site-packages/sqlite/main.py", line 503, in
_begin
self.db.execute("BEGIN")
DatabaseError: database is full
Christopher Schmidt
MetaCarta
I cleared up a little space, in my home folder, not too much. But was enough to get mysql restarted and Drupal back up. Thanks for pinging about this problem Chris. The trouble brings us back to this old issue:
http://trac.osgeo.org/osgeo/ticket/126
On the 6th, /var/lib/mysql *.bin files started stacking up again, often twice per hour at 1GB+. Not sure what changed.
Tyler
dispatch_request
dispatch
process_request
self._do_login(req)
_do_login
execute
execute
self.con._begin()
_begin
Christopher Schmidt
MetaCarta
Sac mailing list
Sac@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/sac
Tyler Mitchell
Executive Director
Open Source Geospatial Foundation
tmitchell@osgeo.org
P: +1-250-277-1621
M: +1-250-303-1831
What changed is that we have 4 new databases for Drupal. IOW
odgeo_drupal osgeo_fdo osgeo_mapguide and osgeo_mapbender should be
duped and mothballed, and then deleted from mysql. The new databases are
called drupal_osgeo, drupal_fdo, drupal_mapguide and drupal_mapbender.
Also I changed the drupal cron job to run on all four sites once per
hour (it might create some additional stuff like search indexes etc, but
should not be such a biggie)
--Wolf
Tyler
dispatch_request
dispatch
process_request
self._do_login(req)
_do_login
execute
execute
self.con._begin()
_begin
Christopher Schmidt
MetaCarta
Sac mailing list
Sac@lists.osgeo.org
Tyler Mitchell
Executive Director
tmitchell@osgeo.org
P: +1-250-277-1621
M: +1-250-303-1831
Sac mailing list
Sac@lists.osgeo.org
<:3 )---- Wolf Bergenheim ----( 8:>
