this LDAP+geonetwork hookup sounds exciting, i would be interested in
trying it out at some more restful time, connecting the OSGeo LDAP to
the geonetwork installation at telascience so people can... er
contribute geodata ...
----- Forwarded message from Simon Pigot <p76corty@tpg.com.au> -----
Date: Sat, 10 Mar 2007 13:33:19 +1100
To: geonetwork-devel@lists.sourceforge.net
Hi Everyone,
We've implemented an OpenLDAP solution with geonetwork 2.0.2/3 that
might be of interest to the community.
The basics are:
1. Uses the intrinsic JNDI interface
2. Integrates existing directories into a specific geonetwork directory:
- using an OU or organizationalUnit with children that are referrals
to existing LDAP directories for authentication (can be any number)
eg. ou=authentication in our geonetwork directory has three referrals to
remote ldap servers:
- ou=adpeople (active directory people) slurped from Windows domain A/D
- ou=extpeople (external people)
- ou=ftp (people from our ftp server)
3. Admin overhead is removed by authenticating against each child of
ou=authentication and then adding users from those existing LDAP
directories to an ou=geonetworkusers and groups in ou=geonetworkgroups.
Specifically:
- new user to a child ou of ou=geonetworkusers eg. a user geoff
authenticated against ou=adpeople would be added as
uid=geoff,ou=adpeople,ou=geonetworkusers,..... - given a profile of
RegisteredUser and a generated userid
- a group representing the ou they logged in from is created if not
present and/or the user is added as a member
- an invisible group with just the new user as the only member for use
when creating new metadata records
4. I've removed the user admin interface (coz ldap users do these kinds
of things elsewhere and we don't need the userPassword field in the
geonetwork directory) and changed the groups interface to just a show
and list (still need to add a group mod interface)
5. You can have a group as a member of a group eg. my registeredusers
group has three group members: adpeople, extpeople and ftp
6. ldap replaces users, groups and usergroups tables in geonetwork
database implementation - rest of the geonetwork db implementation
remains the same
It's kind of a minimalist approach but it works well and draws on some
of the strengths of the ldap hierarchy. But I think the lack of an admin
overhead is helpful - the geonetwork user and group stuff is built from
existing directories.
Anyways its a suggestion about how an LDAP implementation could be done.
I did add some simple schema objectclasses (geonetworkUser and
geonetworkGroup) which use built in ldap attributes (eg uidNumber and
gidNumber) and use OIDs from the experimental range.
Simon
opinions on IT & business topics through brief surveys-and earn cash
GeoNetwork-devel mailing list
----- End forwarded message -----
