Björn, or anyone else: could you figur out how would that be done ?
Ideally we'd have a project setup as a mirror of an SVN project
and using the trac external ticket tracker.
Otherwise, there is probably a way to do this, either using git hooks or
with cron script using the gitlab/github API.
Personally I find it discouraging to be forced to look for workarounds
to the lack of willingness to open up the code. It surely doesn't make
me willing to contribute to the project.
But of course the GitLab champions are welcome to try that out.
On Wed, Aug 31, 2016 at 12:40:03PM +0200, Vincent Picavet (ml) wrote:
> Hi,
> On 31/08/2016 12:01, Sandro Santilli wrote:
> > I was unable to find the "Repository Mirroring" section in the PostGIS
> > project configuration on OSGeo GitLab instance. The section should be
> > there according to
> > http://docs.gitlab.com/ee/workflow/repository_mirroring.
html#existing-projects
> This is a EE-only feature, as you can see here :
> https://about.gitlab.com/features/
> Maybe this project may help :
> https://github.com/samrocketman/gitlab-mirrors
--strk;
I share some of the concern about the CE/EE model that GitLab has and agree
it might discourage contribution. But at the same time, I'm not totally
against this model either as long as the CE version is forkable, useful and
superior to other alternatives. After all, even PostgreSQL have an
enterprise ecosystem around it.
I'm looking forward to see the superior features.
So far I noticed its lack of mirroring support and federated avatars.
Chances are it would support PR build status via drone, but I didn't
fully try that (Gogs connector for Drone is still not supporting PRs).
Den 31 aug. 2016 3:12 em skrev “Sandro Santilli” <strk@kbt.io>:
it might discourage contribution. But at the same time, I’m not totally
I’m looking forward to see the superior features.
Chances are it would support PR build status via drone, but I didn’t
–strk;
Agreed. I did not mean to imply that GitLab CE is superior to anything, merely that it might be worth evaluating. I also find the intentional lack of simple built in mirroring a significant minus so it will have to weight up for that in my opinion.
