I wonder if someone could lend me a hand (say, knowledge) to
run 'cvs2svn' well for the GRASS CVS migration [1].
We have numerous branches and HEAD to be migrated.
First tests (see Web page below) didn't run well so we
have to figure out the right flags. I assume that much experience
was already gained in the GDAL and Mapserver (and other)
OSGeo projects.
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
FBK-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
The biggest problem I found with cvs2svn was it can't deal well with branches that are *also* tags of the same name. This wasn't a problem for GDAL because there were so few branches. It was a small problem for MapServer, as a couple of early releases had both the branch and the tag for the release named the same. In that instance, you have to choose. What I did was force cvs2svn to create a branch from that instead of a tag, and then I manually copied the branch to a tag representing the release (all branches/tags in Subversions are just copies). The arguments in the command being used on the wiki appear to be doing --force-branch, which IIRC was the method I used to do this.
We did break the sponsor logos in the GDAL repo, and just re-imported them after standing up the repository. I don't know if identifying and re-importing your non-kb binary files after the fact is reasonable for the GRASS repository.
I don't understand the question about timestamps of files. cvs2svn should maintain the entire history for a file when it commits it to subversion. Is it just screwing up the very last commit?
Howard
On Aug 13, 2007, at 8:17 AM, Markus Neteler wrote:
OSGeo projects.
Sac mailing list
Sac@lists.osgeo.org Sac Info Page
