The NFS mounted /home disk on xblade14-2 was giving problems so I umounted
it using "umount -l /home" (thanks Wolf!). I suspect other blades will be
similarly affected.
I'm planning to leave the nfs /home not mounted on xblade14-2 till things
are more stable again.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | President OSGeo, http://osgeo.org
On Nov 28, 2007 3:57 PM, Frank Warmerdam <warmerdam@pobox.com> wrote:
Folks,
similarly affected.
Folks,
similarly affected.
It is accurate to the best of my knowledge though I'm not sure it reflects
all the "hyper*" activity.
Did you see a particular issue with it?
Best regards,
On Thu, Nov 29, 2007 at 09:32:39AM -0500, Frank Warmerdam wrote:
>>Folks,
>>similarly affected.
>Frank,
>does
> http://wiki.osgeo.org/index.php/SAC_Service_Status#Telascience_Blades
>still reflect the current usage? Please update (someone), if not.
Markus,
The Hyper machines are not actually blades, but I will upate the
HyperCube page with more details about its current usage sometime soon.
Just curious, and sorry to come late to the discussion.... is there
-any- way I can get the contents of my home dir back?
If you could drop them off in /osgeo/mapbuilder, that'd be ideal.
-Matthew D. Diez
On Nov 28, 2007 8:57 AM, Frank Warmerdam <warmerdam@pobox.com> wrote:
Folks,
similarly affected.
Best regards,
Matt,
I imagine they are available under /home on other systems, like
geodata.telascience.org for which the same account you used on
xblade14-2 should work.
Best regards,
