Hello,
The OSL is working on our internal ganeti cluster and we need to schedule downtime from 9-11 AM PDT, (16:00-18:00 UTC), On Wednesday June 7th (6/7). The OSL has been working to rotate a few racks we have so that we can finish the transition to hot and cold isles in our data center. 3 of our ganeti nodes in our cluster are in a rack that needs rotating, so we need to vacate these nodes in order to minimize downtime while we rotate the servers. This is the first step toward finishing the last racks we need to rotate. The VMs we are moving are high impact and will move to another node that is unaffected by the move, so this should be the only downtime for these VMs in relation to the move. VMs remaining on the affected nodes will have an longer downtime when we make the move. If you want to you know if you’re affect and want to move your VM ahead of time, please let us know directly.
The following VMs will be affected:
ntpsec-service1.osuosl.org
ntpsec-service2.osuosl.org
ntpsec-service3.osuosl.org
Each VM should be down for about 5 minutes, however we are scheduling 2 hours in case of any issues we come across.
If you have any questions or concerns, please contact us at support@osuosl.org
