All,
I wanted to pass along more information on where we’re at and our current plans to try and work around this issue.
Without going deep into the history of our core network infrastructure, we have two core “routers” that are both aging and we’re in the process of replacing them with something newer.
Previously, our uplink was connected through our Cisco 6509. This switch has several 1G line cards that half of our servers are directly connected to.
The other core switch is a Cisco Nexus 6001 which has three fabric extenders which provide 1G connectivity to the other half of our servers. When we migrated over to the LinkOregon network, we moved the uplink over to this Nexus 6k as it was much easier to get LR optics for it.
Unfortunately this Nexus 6k has started kernel panicking and rebooting in the past several months multiple times causing these outages. Much of our downlink 10G switches are connected to this Nexus 6k which means there’s a larger impact when it goes down.
A few years ago a high speed trading company donated us a pallet full of Arista switches and I’ve been slowly adding to our infrastructure. Even though they are EOL, they still work very well and we haven’t had any problems with them. And since I have a lot of them, I can easily replace one if one goes bad.
My current plan is to set up one of these Arista switches and move all of the current 10G connections to it. This way, at least we can reduce the impact if/when this Nexus 6k switch reboots again. In theory, it should only affect the servers directly connected to the FEX switches if it reboots again.
I reached out to the OSU IT community and they graciously donated two 10G-LR optical modules so that I can put this plan in place without having to wait to ship modules.
Current plan for today:
- Setup new Arista switch
- Move upstream connectivity to LinkOregon to it
- Move all downstream 10G links to this router
I will send another email when I plan to do the actual outages for the cut over.
Longer term plans
- Work with vendors to replace our aging core network infrastructure with something that’s still supported and we can afford
- Look into getting redundancy put into place so that we don’t have this issue anymore
- Migrate off of the older equipment
If anyone on this list has connections to Arista or any other major edge networking vendor, please let me know. That will certainly help our situation in the long term!
I had already started working on a plan to replace these systems but it seems my time may have run out (at least for the Nexus 6k switch).
Thanks all for your patience and support!
Lance Albertson
Director
Oregon State University | Open Source Lab
