I'm seeing http://svn.osgeo.org/ or http://trac.osgeo.org/ not responding, at
least not reliably enough to be able to file a SAC ticket Confirmed from
someone from the US, so not an issue at my end.
On Sun, May 8, 2016 at 6:17 PM, Even Rouault <even.rouault@spatialys.com> wrote:
On Mon, May 09, 2016 at 10:04:48PM +0200, Markus Neteler wrote:
On May 9, 2016 10:02 PM, "Sandro Santilli" <strk@keybit.net> wrote:
> On Mon, May 09, 2016 at 09:35:06PM +0200, Markus Neteler wrote:
> > Hi,
> > at time trac is almost unusable
> > I can neither update tickets nor get into the admin panel.... (GRASS
> > GIS trac). Timeout..
> > Any idea?
> You're probably banned by osgeo-http-dos.
Grrrr
It looks like more than 30 requests are easy to do in 2 minutes.
Especially when using SVN (now that I checked)
I've reduced the check so it takes 30+ requests in 1 minute now,
and only check trac (jail name changed accordingly).
Don't reload too much !
> Which IP do you come from ?
Sorry, no idea. I left the office in favor of dinner... It is a Telekom
Germany connection AFAIK.
The ban lasts 15 minutes. While banned you'll get the timeout as you
mentioned.
Le lundi 09 mai 2016 00:17:32, Even Rouault a écrit :
at least not reliably enough to be able to file a SAC ticket Confirmed
from someone from the US, so not an issue at my end.
http://trac.osgeo.org/ has started again being unresponsive since
approximately 10 minutes.
Sandro seemed to suggest this might be due to to the fail2ban script running
(not sure if I understood well) ? Anyway making it run while preserving some
disponibility of Trac ?
On Tue, May 10, 2016 at 03:20:37PM +0200, Markus Neteler wrote:
On Tue, May 10, 2016 at 3:05 PM, Markus Neteler <neteler@osgeo.org> wrote:
> On Tue, May 10, 2016 at 2:48 PM, Markus Neteler <neteler@osgeo.org> wrote:
>> Back in the office now - but still blocked!
> Indeed: again blocked. I just checked on trac:
> 2016-05-10 06:02:36,617 fail2ban.actions: WARNING [osgeo-trac-auth]
> Ban 217.86.229.XXX
> So I cannot even authenticate at time.
Since I wanted to continue, I have now whitelisted my IP
Approved
Anyway, the 'osgeo-trac-auth' ban doesn't have to do with reloads
or excessive requests, but with authentication failures. Check out
the rule, and let me know if you think it needs to be tweaked.
> Hi,
My hypotesis was that your IP got cought by fail2ban, which would result
in a 10 minutes ban (if found failing more than an authentication) or in
a 15 minutes ban (if found to be making more than 30 requests in one
minute). If this is the case, the TCP packets would be dropped so you
would never get a response within the ban timeframe.
I could dig more if you gave me the IP you are coming from.
> > Hi,
> > responding, at least not reliably enough to be able to file a SAC
> > ticket Confirmed from someone from the US, so not an issue at my
> > end.
> running (not sure if I understood well) ? Anyway making it run while
> preserving some disponibility of Trac ?
(off-list response to avoid my ip being too widespreadly known)
My IP (fixed) : 88.162.84.61
Could you white-list it ?
> > Hi,
> > end.
That might probably be it. This restarted working, and right now I'm stuck
again (both Trac and SVN rejecting me)
This fail2ban mechanism seems to prevent legitimate uses. Yes, I do refresh
Trac or do svn operations a lot when working on GDAL.
(seing that my "off-list" attempt ended up on the list... anyway... )
