Today tracsvn container cannot connect LDAP server.
The current configuration for LDAP client on that machine
is to use the public DNS name for the service (ldap.osgeo.org)
but attempts to reach that host on port 389 hangs indefinitely.
Hitting the host on port 636 is fine, with netcat:
tracsvn:~# nc -vz ldap.osgeo.org 636
DNS fwd/rev mismatch: ldap.osgeo.org != base.osgeo.osuosl.org
ldap.osgeo.org [140.211.15.57] 636 (ldaps) open
But "can't contact" with ldapsearch:
tracsvn:~# ldapsearch -H ldaps://ldap.osgeo.org:636 -x 'uid=strk'
ldap_sasl_bind(SIMPLE): Can't contact LDAP server (-1)
The LXD configuration on osgeo7 requests to listen on port 636
for the ldap.osgeo.org IP (140.211.15.57) and connect it to port
636 of 127.0.0.1 of the "secure" container. Indeed I cannot contact
the server on that port from secure:
secure:~# ldapsearch -H ldaps://127.0.0.1:636 -x 'uid=strk'
While I do can see the ports open (both 636 and 389):
secure:~# netstat -tnlp | grep '\(389\|636\)'
tcp 0 0 0.0.0.0:636 0.0.0.0:* LISTEN 29044/slapd
tcp 0 0 0.0.0.0:389 0.0.0.0:* LISTEN 29044/slapd
tcp6 0 0 :::636 :::* LISTEN 29044/slapd
tcp6 0 0 :::389 :::* LISTEN 29044/slapd
Logs from the journal don't even see attempts to connect, but the
startup messages do contain some info about failures:
secure:~# journalctl -x -u slapd.service -f
Mar 02 08:30:05 secure systemd[1]: slapd.service: Failed to reset devices.list: Operation not permitted
Mar 02 08:30:05 secure systemd[1]: slapd.service: Failed to set invocation ID on control group /system.slice/slapd.service, ignoring: Operation not permitted
Ever saw those messages? Ideas what could we be up to ?
Shall I blindly try a stop/start cycle on the LXD container ?
--strk;
() Free GIS & Flash consultant/developer
/\ https://strk.kbt.io/services.html
