Hello,
the Mapbender team wants to use the two VMs :
* AdhocVM (as a testbed)
* ProjectsVM (1. to show our demos and 2. to move mapbender.org after FOSS4G)
This is what I want to do in the next days:
AdhocVM
1) I would create the directory /osgeo on adhocvm (like it is on projectsvm)
2) I would install svn on adhocvm
3) I would install PostgreSQL/PostGIS on adhocvm
4) I would install php on adhocvm
5) install gettext
ProjectsVM
1) we want to move mapbender.org to ProjectsVM in the future but not
before FOSS4G
2) we want to set up mapbender demos at somthing like
projects.mapbender.osgeo.org on the ProjectsVM - which was former on
telascience
3) who is already using PostgreSQL on the ProjectsVM? I would like to
create a new role and mapbender databases. But I don't have the assword to
get access to the database.
I hope the changes will not have any impact on other projects. Else please
let me know.
Best regards
Astrid Emde
FOSS4G 2010
6.-9. September 2010 in Barcelona
http://2010.foss4g.org/
Astrid Emde
WhereGroup GmbH & Co.KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
astrid.emde@wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
On Aug 5, 2010, at 4:05 PM, ext Astrid Emde wrote:
Hello,
AdhocVM
Already exists.
Done.
Done.
Done.
5) install gettext
Done, though I expect you actually want something to hook up PHP to gettext,
which isn't done, because I don't know what you actually want.
ProjectsVM
before FOSS4G
This may be better served by being hosted on the wiki.osgeo.org machine,
depending how much direct access is required; if it's a one-time setup
that SAC can make, it might make more sense to only have Wikipedia
installed in one place.
telascience
createuser -U postgres astrid
createdb -U postgres foo_bar
Any user who has local access to the machine can authenticate as the postgres
user, because users who can access the machine are considered trusted by
Postgres.
-- Chris
Hey Chris,
thanks - you did all the work already.
Hello,
the Mapbender team wants to use the two VMs : * AdhocVM (as a testbed)
FOSS4G)
AdhocVM
projectsvm)
Already exists.
Done.
Done.
Done.
5) install gettext
gettext, which isn't done, because I don't know what you actually want.
we need both php-gettext and gettext.
we use msgfmt to compile our language mo-files
ProjectsVM
before FOSS4G
depending how much direct access is required; if it's a one-time setup that
ok - for us wiki.osgeo.org would be fine too. We have an existing
mediawiki with a MySQL database that has to be moved to another server.
telascience 3) who is already using PostgreSQL on the ProjectsVM? I
would like to create a new role and mapbender databases. But I don't
have the assword to get access to the database.
createuser -U postgres astrid createdb -U postgres foo_bar
postgres user, because users who can access the machine are considered
trusted by Postgres.
ok - thanks. So I will try this.
Astrid
Hello,
1.) On the adhocvm the pg_hba.conf entries differ from the conf-entries on
the projectsvm.
--> I took the same configuration for the adhocvm and did a force-reload
2.) I created a database template_postgis which can be used as a template
for postgis-databases.
Astrid
FOSS4G 2010
Astrid Emde
Siemensstraße 8
53121 Bonn
Germany
www.wheregroup.com
Komplementärin:
vertreten durch:
