Can anyone explain what happens when I go to:
http://mapguide.org
It redirects to:
https://mapguide.osgeo.org/
(note the https)
But that fails with error:
Forbidden
You don't have permission to access / on this server.
What don't we have set up right?
Tyler
http://mapguide.org
It redirects to:
(note the https)
Forbidden
Tyler,
We don't seem to control mapguide.org. I guess Autodesk still holds it.
It likely has a CNAME forwarding to https://mapguide.osgeo.org/. It likely
ought to forward to http://mapguide.osgeo.org/
However, we could look into https enabling mapguide.osgeo.org. I'll take a
quick look.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | President OSGeo, http://osgeo.org
Actually let me see if I can get mapguide.org fixed...
Bob
http://mapguide.org
It redirects to:
(note the https)
Forbidden
Tyler,
quick look.
Best regards,
Frank wrote:
Tyler,
quick look.
Best regards,
Bob,
I haven't made any changes for https://mapguide.osgeo.org/. Jason pointed
out that the following url currently does work. I'm quite confused what aspect
of our wildcarding this is going through!
https://mapguide.osgeo.org/mapguide/branches/1.1.x/MgDev/Server/src/Common/Manager/LogThread.cpp
What I had done is change fdo.osgeo.org. I moved the fdo host config out
of /etc/httpd/conf.d/virtual_host.conf into /etc/httpd/conf.d/hosts/fdo.conf
and added a :443 virtual host so that https://fdo.osgeo.org/ also goes to
the normal drupal instance.
After restarting apache I noticed that the https://fdo.osgeo.org traffic
still gets logged in /var/log/httpd/access_log instead of ssl_access_log.
Is there a specific reason we keep these separate?
And what is the distinction between the ssl_request_log and the ssl_access_log?
If there are no objections, I can also update the mapguide.osgeo.org config
similarly to the fdo.osgeo.org config. If anyone notices that my changes
have broken something with the fdo.osgeo.org config, let me know.
Best regards,
