I seem to have blown up our Trac instance. I keep getting this error:
Python Traceback
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 387, in dispatch_request
dispatcher.dispatch(req)
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 191, in dispatch
chosen_handler = self._pre_process_request(req, chosen_handler)
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 263, in _pre_process_request
chosen_handler = f.pre_process_request(req, chosen_handler)
File "/usr/lib/python2.3/site-packages/trac/versioncontrol/api.py", line 73, in pre_process_request
self.get_repository(req.authname) # triggers a sync if applicable
File "/usr/lib/python2.3/site-packages/trac/versioncontrol/api.py", line 101, in get_repository
repos = self._connector.get_repository(rtype, rdir, authname)
File "/usr/lib/python2.3/site-packages/trac/versioncontrol/svn_fs.py", line 259, in get_repository
repos = SubversionRepository(dir, None, self.log)
File "/usr/lib/python2.3/site-packages/trac/versioncontrol/svn_fs.py", line 292, in __init__
self.repos = repos.svn_repos_open(self.path, self.pool())
SubversionException: ("Berkeley DB error while opening 'uuids' table for filesystem /var/www/svn/repos/mapguide/db:\nCannot allocate memory", 160029)
From trac-admin I get:
Command failed: (‘Berkeley DB error while opening environment for filesystem /var/www/svn/repos/mapguide/db:\nPermission denied’, 160029)
I have switched off the pre and post hook scripts for now and did an 'svnadmin recover' on the mapguide repository. Can you confirm we're good?
Howard
Python Traceback Traceback (most recent call last): File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 387, in dispatch_request dispatcher.dispatch(req) File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 191, in dispatch chosen_handler = self._pre_process_request(req, chosen_handler) File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 263, in _pre_process_request chosen_handler = f.pre_process_request(req, chosen_handler) File "/usr/lib/python2.3/site-packages/trac/versioncontrol/api.py", line 73, in pre_process_request self.get_repository(req.authname) # triggers a sync if applicable File "/usr/lib/python2.3/site-packages/trac/versioncontrol/api.py", line 101, in get_repository repos = self._connector.get_repository(rtype, rdir, authname) File "/usr/lib/python2.3/site-packages/trac/versioncontrol/svn_fs.py", line 259, in get_repository repos = SubversionRepository(dir, None, self.log) File "/usr/lib/python2.3/site-packages/trac/versioncontrol/svn_fs.py", line 292, in __init__ self.repos = repos.svn_repos_open(self.path, self.pool()) SubversionException: ("Berkeley DB error while opening 'uuids' table for filesystem /var/www/svn/repos/mapguide/db:\nCannot allocate memory", 160029)
Command failed: ('Berkeley DB error while opening environment for filesystem /var/www/svn/repos/mapguide/db:\nPermission denied', 160029)
Any ideas?
Bob
Sac mailing list
Sac@lists.osgeo.org Sac Info Page
Yes it looks fine now. Might just be another SVN hang like we have been seeing. Maybe it would be a good idea to keep the hooks disabled until we get SVN upgraded, just to eliminate extra pieces in the puzzle.
Bob
Howard Butler wrote:
Bob,
Howard
Bob
Bob,
Howard
Bob
Bob,
Howard
Any ideas?
Bob
Sac mailing list
Sac mailing list
Sac mailing list
Sac mailing list
Doing a full backup of all repositories now, then upgrading to
subversion 1.4.3
All tests were fine on my test server.
Upgrade should be completed by 11 am EST.
shawn
Back again. We need to get upgraded soon
On Jan 29, 2007, at 11:08 PM, Robert Bray wrote:
Well at least it was ok, but now it is down again
Bob
Bob
Bob,
we're good?
Howard
self.log) File
160029)
Time change for subversion upgrade. Currently i'm merging all fdo
projects into one repository. I'll upgrade subversion when all merging
is done.
shawn
subversion 1.4.3
shawn
Bob
Bob
Bob,
we're good?
Howard
self.log) File
160029)
